Old March 10th, 2010, 19:07
seth15210's Avatar
seth15210 seth15210 is offline
arb turn signals/ running lights
so i just got done installing my arb bull bar. i havent wired up the turn signals and i want to wire them as running lights also. ive read a thread a while ago and the guy said that the lens started melting. has anyone else done this. i thought just changing the bulb to a lower watt bulb would prevent that. or even getting some led bulbs. any input is welcomed
Old March 10th, 2010, 19:11
IllianaXJ's Avatar
IllianaXJ IllianaXJ is offline
Support Your Local Trails
Re: arb turn signals/ running lights
IIRC the ARB bulbs are single wire and single filament. You would have to get a dual filament socket and bulb to wire it up that way.
MWC Vice President
1995 XJ Sport Mallcrawler build
2000 GMC Yukon XL 2500 6.0/4L80e
Old March 10th, 2010, 19:15
seth15210's Avatar
ya i noticed that. im leaning towards the led route.
Old March 10th, 2010, 19:17
ADVNTURR's Avatar
ADVNTURR ADVNTURR is offline
I worry when rattles stop
I melted the lenses on my ARB lights when I had them set up as parking lights. I would recommend setting them up as turn signals only and if you can find a set of LED lights to use (they should be amber not white) I would recommend them as well. I actually do not have mine installed currently because I had some water/mud get into one and corrode everything. I plan on mounting an LED in it an sealing it up with some RTV, but it doesn't rank too highly on my "to-do" list right now.
Old March 10th, 2010, 19:24
seth15210's Avatar
thats what i needed to hear. i dont wanna melt the lenses but i do want extra running lights. im gonna hunt locally for the led's. has anyone figured what driving lights fit in that slot.
Old March 11th, 2010, 06:20
Talyn's Avatar
Talyn Talyn is offline
Don't wire them as constantly on. I.e. Parking lights. The Lens will melt with a standard incandescent bulb. Just wire them in as blinkers. I haven't found a drop in LED bulb that is actually bright enough.
Old March 11th, 2010, 13:42
seth15210's Avatar
i stopped at a pep boys today and they had a bulb that was a blinker thatll fit. didnt get it yet, still debating
Old March 11th, 2010, 14:10
gm tech gm tech is offline
sry to hijack but how long/where did you order your arb bull bar from
i just orderd one for my 99 xj from 4wd.com and they told me it was on back orderd with no ETA and was a direct ship from ARB?
Old March 11th, 2010, 14:35
Markos Markos is offline
Considering the fact that ARB uses rabbit lenses, you aren't doing anything that hasn't been done before. I suggest that you search around on www.vwvortex.com
Old March 12th, 2010, 10:59
seth15210's Avatar
I got mine from 4wd. They had one come in for someone else and they cancelled last min. So the day I ordered it I picked it up two hours later. Good timing is all
Old March 12th, 2010, 16:48
Vaulter09 Vaulter09 is offline
That's a random piece of knowledge that I didn't know anyone else had figured out. Well done!
Old March 15th, 2010, 12:41
Talyn's Avatar
I thought it was common knowledge that ARBs used VW lenses?
Parking lights and turn signals Mudd Digga OEM Tech Discussion 2 June 14th, 2009 18:11
Marker lights, turn signals, DOT H4 Vince OEM Tech Discussion 9 January 17th, 2009 16:00
brake lights and turn signals not working??? MarioWario OEM Tech Discussion 15 January 3rd, 2009 19:43
No reverse lights or brake lights or turn signals... TheHighHeat OEM Tech Discussion 6 October 5th, 2008 15:13
96- no brake lights or turn signals BAs96XJ OEM Tech Discussion 4 November 19th, 2005 17:28
