Old March 6th, 2010, 19:08
Dave Meyers's Avatar
Dave Meyers Dave Meyers is offline
Smile Finally solved no heat issue
Heater core was plugged up. Prior to radiator swap, I used stop leak as an emergency fix to get me across country, long after the road trip, when the stop leak finally failed, I swapped the radiator but then had no heat. Flushing the heater core with the hose had not previously helped. Today I reversed the heater core hoses to reverse the flow and instantly regained my heat. Then refilled system with anti-freeze, put hoses back, and all is good.
Old March 6th, 2010, 20:34
joe_peters joe_peters is offline
Re: Finally solved no heat issue
Interesting--a new method of back-flushing the heater core!
Had you tried a number of times to clear the heater core, perhaps with a commercial flush product?
How about a brief recap of the no-heat issue? What you did, along with what has finally worked, could really help others down the road.
Old March 7th, 2010, 15:32
Checked the usual suspects, blend door, T Stat, coolant, no luck. Also flushed the heater core with a garden hose, no change. Then one mechanic said he would do the hose swap backflush if I brought it in, but I thought I could do it for free, so I did. Another mechanic, whom I trust a great deal, suggested that I disconnect the heater hoses from the block, blow the coolant out of the heater core and then fill it with The Works Original Toilet Bowl Cleaner, let it sit for several minutes, rinse both directions with the hose and repeat. It may bubble while sitting there. I was going to do this if the first method I tried did not work. I also wondered if my heater core would have unplugged itself after a while, because the stop leak usually fails after some time. But my heat was not improving. It was amazing that the heater core instantly unplugged doing the hose swap. I lost practically no coolant in the process, so a no cost fix. Not typically my luck.
Old March 7th, 2010, 16:28
Glad it worked for you.
By providing the details you will likely help someone else down the road.
Old March 7th, 2010, 17:13
Talyn Talyn is offline
The only thing I would like to know is where the clog went to?
Old March 7th, 2010, 17:17
Here: http://www.clog.org/
Old March 7th, 2010, 17:26
Originally Posted by joe_peters View Post
Thats just horrible. Kind of along the lines of curling
Old March 7th, 2010, 18:15
I think that is how you keep the clogs on--curling your toes.
Old March 7th, 2010, 18:27
orange orange is offline
Did you flush from the front thru the heater control valve->heater->valve ? Maybe something stuck in the valve?
Old March 7th, 2010, 18:30
A great comment. The best thing to do after this kinda fix is drain and refill.
Old March 7th, 2010, 19:16
From his profile he has a 2000, which doesn't have a heater valve.
Old March 7th, 2010, 19:34
Thanks!
Old March 7th, 2010, 21:05
Thanks!
Missed your post...that's accurate, I have no heater control valve on the 2000 XJ.
Old March 7th, 2010, 21:35
Thanks 2.
Good Luck,
Orange
Old March 7th, 2010, 21:37
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
It could be worse.
You just know the "clog" went somewhere!!
I guess The Works Original Toilet Bowl Cleaner just dissolves it. End of story. Happy ending.
1990 XJ - 4.0L AW4 It's white.
1988 MJ - 4.0L AW4 It's green.
no heat - solved Dave Meyers OEM Tech Discussion 8 October 11th, 2009 16:00
Vibration/Noise issue solved! mbogosia Modified Tech Discussion 0 January 4th, 2009 07:48
overheating at freeway speeds issue still not solved!!! AZRockRunner Arizona Chapter 41 June 17th, 2007 01:18
interesting AX-15 issue, semi-solved gmars OEM Tech Discussion 4 December 6th, 2006 15:00
I think I solved my overheating issue! GottaBeJeep Modified Tech Discussion 7 June 14th, 2005 19:33
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
