Old November 5th, 2006, 07:18
SPIKEHORN SPIKEHORN is offline
FRONT END NOISE 1999 JEEP XJ 4X4
I am a new member as of about 15 min.ago. I am hoping to keep my Jeep in tip top condition. Got wheel wander and whirring sound coming from left front. Bearing hub assy? Please help!
Thanks,
SPIKEHORN
Old November 5th, 2006, 08:51
falcon556's Avatar
falcon556 falcon556 is offline
I have not Confirmed, or I used a BAD email Addy
Re: FRONT END NOISE 1999 JEEP XJ 4X4
[QUOTE=SPIKEHORN]I am a new member as of about 15 min.ago. I am hoping to keep my Jeep in tip top condition. Got wheel wander and whirring sound coming from left front. Bearing hub assy? Please help!
Thanks,
Usually if it is the hub, the sound changes when you turn the wheel because the load on the bearings change.
Try turning the wheel left-right.
While driving:-)
Old November 5th, 2006, 12:15
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Sounds like a hub to me, especially if you're feeling wander along with it. Sometimes if the bearing surfaces are pitted or spalled, there will be no discernible play in the bearing, and the sound won't change much with steering. If it does change, or there is play, it's definitely the bearing, but if it doesn't, don't stop there: jack up the wheel and turn it to feel and listen for roughness or rumble. It should be smooth.
Old November 5th, 2006, 12:19
88JeepXJ's Avatar
88JeepXJ 88JeepXJ is offline
Wheel wonder sounds like Jeep design/worn out tie rod ends in the steering system. Whirrling sound is almost definately wheel hub/bearing unless you have knobby and/or out of balance tires.
Old November 5th, 2006, 16:13
MATT, FALCON AND 88,
Thanks for your input. I replaced the left hub this afternoon. The sounds are GONE! One little problem though... I hear some clunking coming from the left front when turning/backing. Maybe I didn' t torque things enough. Can I please ask you fellas to pick your brains again? Y'all have been quite helpful. I REALLY appreciate your assistance. Site is AWESOME!
SPIKEHORN
1999 Jeep Cherokee Sport 4WD 5-speed bjlinma NAC Classifieds 4 November 19th, 2006 19:13
squealing noise from front of jeep Boulder_jeeps OEM Tech Discussion 3 August 8th, 2006 21:21
1999 Jeep XJ Lifted, locker, 33's manganos For Sale: Private Party Only. XJ ITEMS ONLY 1 August 2nd, 2006 04:07
1999 Jeep Cherokee XJ tubbinator For Sale: Private Party Only. XJ ITEMS ONLY 2 July 2nd, 2006 21:27
Stock Air Box For My 1999 Jeep Cherokee chipsahui2 Wanted: Private Party Only 8 November 16th, 2003 13:35
