Old February 14th, 2010, 03:53
joalyons joalyons is offline
P0463 - Fuel Gauge Reads Empty
Our fuel gauge in the 98 XJ doesnt work so I checked the codes and Im getting P0463. I checked the Ohms at the fuel pump plug and it seemed weird so I replaced the fuel pump and sending unit. When I pulled the tank and the old sending unit the Ohms seemed fine, but I installed the new one anyway and I still have the same problem, fuel gauge reads empty. I cleared the code and it comes right back, any ideas on where the problem could be, a bad ground, bad connection to the computer? Any ideas would be helpful.
Old February 14th, 2010, 19:00
Re: P0463 - Fuel Gauge Reads Empty
Found the problem, started to trace the wires from the pump up to the computer and found that the ground wire had broken in the rubber grommet right under the rear seat where the wires go into the passenger compartment. Easy fix, some new wire, and heat shrink tubing and I was done. Hopefully this will help someone else find the issue.
Old February 15th, 2010, 13:39
epitaphmike's Avatar
epitaphmike epitaphmike is offline
I hope that is my problem. I also have a 98 XJ and mine just stopped working too. I also had to replace my fuel pump because regulator took a crap, then the new pumps regulator took a crap a month later. I'm on to new pump #2. All seems good so far...
Old May 17th, 2010, 09:16
slowjeep slowjeep is offline
I just that code after plugging in the scanner, wasn't even getting check engine light, I was looking to fix the airbag light. P0463 (Fuel level sensor A circuit high), I will have to check the wiring under the seats, thanks joalyons for the tip.
Old August 17th, 2010, 15:14
Baloozabub Baloozabub is offline
Same problem hope this is all that it takes!
Help. Fuel gauge reads opposite of whats in the tank chicoxj OEM Tech Discussion 8 May 3rd, 2009 23:23
Gas Gauge Reads Empty But... HaddenhasaXJ OEM Tech Discussion 17 December 27th, 2008 18:07
Swapped in a 94 cluster, swapped out the sensor in the T-stat housing, gauge reads 0 Plays For Jeeps OEM Tech Discussion 4 April 1st, 2007 13:26
Gas Gauge always reads full CherokeeDude OEM Tech Discussion 4 December 8th, 2006 07:14
Code Scan => P0463 Fuel Level Sensor A Circuit High Input joey99jb Modified Tech Discussion 0 July 26th, 2004 10:31
