Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old February 6th, 2010, 07:53
RBFab's Avatar
RBFab RBFab is offline
Wheel bearing/hub bolts??
Hey all,
So I broke a front axle and had to drive on it a couple miles.Yeah I know big mistake,but it was after midnight and snowing and freezing cold.I only drove like 5mph.So anyway no surprise the busted axle chewed half the heads off the bolts that hold the hub assembly in place.I figured no biggie Ill go to the 'yard and grab a few.Well the 'yards around here apparently feel that salvage parts are 'good as new',and wont even sell me the bolts unless I buy the whole hub assembly.I figure 'hey no prob I could get a few miles out of a used hub assembly'.Well the prob is that they think a USED hub assembly is worth at least $75.00!!! Yeah I can get Timkens new for $95.00,no thanks! SOOOO,my question is does anyone know where to get these bolts at a reasonable price or has anyone just used high-grade hardware store bolts? The hardware store stuff makes me nervous cause these bolts are holding your whole world together when youre cruisin down the highway!
Old February 6th, 2010, 08:05
Justpunchit's Avatar
Justpunchit Justpunchit is offline
NAXJA Member #1291
Re: Wheel bearing/hub bolts??
There size 12x1.75 by 80mm long and make sure you get grade 10.25 and not 8.8 like i did haha. They should be available at any decent hardware store.
95Xj RIP
91Xj gone!
99xj last try?
Old February 6th, 2010, 08:11
RBFab's Avatar
hey thanks for the reply.Yeah that was the plan as far as grade,just wanted to know if anybody had used 'em.How long have you run 'em? were they just standard hex-head? That 12point head seems unnecessary.
Old February 6th, 2010, 08:18
NAXJA Member #1291
I rocked a standard head with a built in collar. and like I said 80mm was just perfect for length
95Xj RIP
91Xj gone!
99xj last try?
Old February 6th, 2010, 09:03
JrTxJ JrTxJ is offline
You can find them in any of the catalogs like Morris4x4, Quadratec, 4wd, etc & good parts stores, or shops that carry Spicer...the oe Jeep # is 34201535
Old February 6th, 2010, 09:10
RBFab's Avatar
thanks for the info,I guess my main thing is that I dont want to pay $7 for a bolt.That would be $42 for all of em,which I need because of a previous axle failure.Just tryin to get it back together cheap because I just bought a bunch of parts.Then again this is a life-support part,so cost shouldnt factor in.
Old February 6th, 2010, 09:14
Oddly the only catalog I see now that 'lists' it is 4wd and they're expensive on it. You could call the other places and ask. If you're paying more than $3 or $4 each you're paying too much.
http://stores.zmjeeps.com/Detail.bok?no=135838
Old February 6th, 2010, 11:06
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
I bought some at the dealer, they were $6 a piece.
Old February 6th, 2010, 12:45
BADaXJ BADaXJ is offline
i bought them at the dealer for 3$ i think. worth a shot to at least check if you have one near by.
Old February 6th, 2010, 19:30
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Originally Posted by RBFab View Post
Hey all,
wow, they're tards it sounds like. Jeff (JrTxJ) already posted the part number, use it on zmjeeps.com and you'll find the bolts for like a buck or three iirc. I use them for most of the bolts I buy because they're about the cheapest I can find aside from going directly to grainger/fastenal etc.
Not sure where this 10.25 is coming from... second time I've seen you use it
EDIT: ah crap, looks like Jeff also posted the zmjeeps link for them, I should read the whole thread before posting
EDIT2: Further, junkyards around me consider bolts "pocket items" (not kidding) - if you bring one up and try to pay they look at you funny and say to take it. Shoot me a PM if you end up needing some other wacky bolt you can't find anywhere, and they're yours for cost of shipping the next time I hit the yard. Just don't ask for a serp belt tensioner bolt or a gas tank bolt, I hate those darn things and buy them new just like every other sucker
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old February 7th, 2010, 07:30
RCP Phx RCP Phx is offline
The bolts are grade 10.9 !
Old February 7th, 2010, 07:46
RBFab's Avatar
Hey thanks for the link! Hope its the right bolt,its not showing a picture or providing a description.
Old February 7th, 2010, 09:38
kastein's Avatar
The part number came from the MOPAR parts catalog (I've verified it just in case) so it should fit great.
rear wheel bearing vs axle bearing philip_g OEM Tech Discussion 4 September 2nd, 2008 19:04
Hub bearing bolts BIGSLVRXJ OEM Tech Discussion 5 April 8th, 2008 09:15
bearing bolts? beakie OEM Tech Discussion 4 October 31st, 2007 04:00
XJ Unit Bearing Bolts!!!!! RAVC1 OEM Tech Discussion 4 September 11th, 2006 17:26
Hub bearing bolts LOCKED UP OEM Tech Discussion 4 November 8th, 2003 18:25
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
