Old January 27th, 2010, 03:08
mhopton mhopton is offline
Blower's blowing, but's not blowing....huh?
OK, have searched and read and have narrowed this down.
- It isn't the blend door - I have very cold, or very hot air - when it's blowing.
- It isn't a vacuum leak - I have air blowing at all of the correct positions, feet, vents, defrotst, etc, when dial is turned.
Essentially, sometimes, when the fan speed is on 1, or 2, or 3, or even 4, I get very little air movement. I can hear the blower blowing like crazy up/down as the fan speed dial moves about, but sometimes, just no air.
Can this be narrowed down to the heater resistor under the dash on the passenger's side? Or, something else?
It *seems* to get better when I flip the temp control from hot to cold, but I'm not for sure.
BTW, 99, auto, 4.0l, 4x4, 90k. All stock.
thanks
Old January 27th, 2010, 05:28
winterbeater's Avatar
winterbeater winterbeater is offline
Re: Blower's blowing, but's not blowing....huh?
The resistor just makes the fan speed change. And is completely bypassed on high speed. Don't know why fan would make a lot of noise like it is blowing, but air not come out anywhere.
Old January 27th, 2010, 21:32
lawsoncl lawsoncl is offline
Is it coming out the wrong vents, like the defroster or floor instead of where you are expecting?
Old January 28th, 2010, 03:03
No, coming out all the correct places, which I'm sure eliminates a vacuum leak. Just minimal blow at each fan setting. High works well though, which is why I think it may be the resistor at the passenger side foot well.
Old January 28th, 2010, 03:59
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
For a bad resistor block, the blower motor will generally work only full blast/high. Turning the switch through the different settings will make NO difference.
If that is the case, suspect the resistor block.
With minimum output at the lower fan settings, your problem may be the switch itself
But if the blower motor rpms go up and down as you move the heater switch, but air movement/output itself varies, I think I'd start looking at the blower motor.
Old January 28th, 2010, 05:27
But blower volume must be directly related to blower rpms unless the "squirrel cage" is spinning on the motor shaft or blocked by something. And if it spun on the shaft much, it would bind up pretty quick.
And the resistor either works or it doesn't. The thermal fuse blows out and takes out all speeds but high.
Old January 28th, 2010, 06:16
Irbys19 Irbys19 is offline
I agree with the previous post i wave seen the blower wheel strip out on the shaft of the blower motor and not want to spin but if thats the case it will eventually stop working.
Old January 28th, 2010, 06:32
skywalkr skywalkr is offline
not to hijack this thread or anything , but I have this problem as well and the air does come out of the wrong vents...I'm thinking its a vacuum leak but am open to suggestion...
Old January 28th, 2010, 07:03
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Probably a vacuum leak or one of the air doors came disconnected from a cable actuator.
As for the OP's problem... maybe something stuck in the ducts blocking the airflow? Maybe the motor shaft stripped out of the blower fan? Maybe the blower motor is actually going really slow, but the brushes are grinding or the windings are humming angrily due to overcurrent from the motor going slow, and it sounds like it's going really fast?
Old January 28th, 2010, 09:03
Default mode is defrost. So with no vacuum, you get defrost. With too little vacuum, you might change to defrost under heavier acceleration.
Old January 28th, 2010, 14:02
that is helpful as it will always work on defrost but nothing else...
Old January 29th, 2010, 04:46
Thanks for the posts and information. I'll pull the resistor and check it but it sounds like maybe I just need to swap out the blower motor. The output is in all the correct places and at the correct temp, it just doesn't...well, put out. We all know that is NO good!!
Old July 18th, 2010, 18:00
Justin M.'s Avatar
Justin M. Justin M. is offline
What did the problem turn out to be? I am having the same symptoms.
Old July 18th, 2010, 18:48
old_man's Avatar
old_man old_man is offline
I fixed one where the squirrel cage was spinning on the motor shaft.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old July 18th, 2010, 18:53
Shorty Shorty is offline
X2^^ motor spun like a champ, but no airflow-- fan was stuck and the motor was "freewheeling" in the fan mount.
88 XJ Blowing Oil F1504x2 OEM Tech Discussion 4 June 22nd, 2009 06:43
Hot air blowing out even when AC is set to cold BlueZombie OEM Tech Discussion 4 May 5th, 2009 18:35
blowing fuses need HELP jeep40driver OEM Tech Discussion 17 April 22nd, 2009 07:56
blowing #2 and #19 fuses? 93xjpos OEM Tech Discussion 8 February 17th, 2008 13:20
A/C blowing at 60F blackbat21 OEM Tech Discussion 13 December 3rd, 2006 14:19
