Old December 23rd, 2009, 17:52
maybe2fast's Avatar
maybe2fast maybe2fast is offline
front end pop when turning
pop in steering when turning hard and leaving a parking spot. Also happens when I am maneuvering through parking lot. Not sure if its related but a 60+ vibration, feels like oval tires almost
u-joints-good
all new ball joints
new MOOG PROBLEM SOLVER trac bar bushing
new (cheap) wheel bearings...I wonder
alignment
NO CHANGE!
recently
front driveshaft cv rebuilt
all front end tight
Old December 23rd, 2009, 17:54
Twisted_Dakota Twisted_Dakota is offline
Re: front end pop when turning
Is the vibration you feel at 60+mph a up and down vibe or a side to side vibe?
Old December 23rd, 2009, 17:57
Begster's Avatar
Begster Begster is offline
It is most likely your frame side trackbar bracket. This is a pretty common problem, and it happened to me.
Try loosening the bolts for the bracket, and then retightening the hell out of them.
Old December 23rd, 2009, 18:17
MrSimon's Avatar
MrSimon MrSimon is offline
Tie rod ends maybe?
NAC Treasurer
Old December 23rd, 2009, 18:26
cruiser54's Avatar
cruiser54 cruiser54 is offline
Do what Begster suggests FIRST before getting off on a tangent. The popping was a problem on the Jeeps when they were brand new. At the dealership we took to tightening the crap out of the frame side track bar bracket during the Pre-Delivery Inspection just to eliminate customer complaints later. This is not a suggestion to be taken lightly. Best case-you fix your problem. Worst case- it won't crop up in the future.
Old December 24th, 2009, 15:05
maybe2fast's Avatar
got a new trac bar bushing MOOG
you think its the bracket that the bar bolts to?
Old December 24th, 2009, 17:28
its the track bar bracket that bolts up to the unibody... Mine does the same thing and I have tighten it as much as possible with lock tight and it still does it...
Anybody think welding it to the unibody would be a bad idea?
Old December 24th, 2009, 17:33
billyjp2's Avatar
billyjp2 billyjp2 is offline
what about the joint in the track bar
Old December 25th, 2009, 05:05
cruiser54's Avatar
Someone suggested loosening all the track bar bracket bolts to the frame and THEN tightening the crap out of them . Worth a try.
Old December 25th, 2009, 09:21
vigman vigman is offline
Had a similar problem a while back. I had a friend turn the wheel all the way to the left and the right while I watched for anything that might have caused it. Come to find out my frame had broken right behind the steering gearbox and the popping was caused by the gearbox not being able to push the wheels and was pushing the frame first
Old December 25th, 2009, 18:39
maybe2fast's Avatar
^hope not
Old January 9th, 2010, 19:14
maybe2fast's Avatar
Soft 8s took care of the highway vibration. Popping still there
Front axle shifts when turning Apostle OEM Tech Discussion 4 October 23rd, 2009 20:47
Very loud front-end clunk when turning SpenceXJ Modified Tech Discussion 28 August 26th, 2008 13:55
Front end jumpy in 4wd while turning x6xdemonx6x OEM Tech Discussion 13 February 10th, 2008 13:58
Front Wheel binding when turning offrd3 OEM Tech Discussion 5 April 16th, 2005 21:26
Front-end thunk or clunk when turning John Saunders OEM Tech Discussion 9 October 21st, 2003 12:00
