is this a RENIX flywheel?
avnsteve
there are 20 teeth between each gap, so 3 gaps, 60 teeth
and overall on the starter ring there are 164 teeth
I just had my tranny out of my 87 Renix. It only has four torque converter bolt holes in the flywheel. Yours seems to have at least six.
I don't know if that info helps you at all though.
Your automatic has a flexplate (not a flywheel), which would indeed have 4 bolts for the torque converter and 6 holes for where it bolts to the crank.
This is a picture of a flywheel which would be used with a manual tranny. The threaded bolt holes around the edge would be where the clutch bolts on.
That makes a whole lot of sense. Thanks for clearing it up.
