Old November 23rd, 2009, 17:31
crazycracka's Avatar
crazycracka crazycracka is offline
Anyone that hasn't adjusted their Throttle Valve cable do it. WOW.
So I posted on here months ago about my Transmission acting weird. In 1-2 selection it would stay in first and not shift to 2nd. In 3 selection it would shift into 4th gear instead of stopping at 3rd. In OD it would shift into OD at like 35 and would have to almost floor it to get it out of OD.
Anyways I never got any clear answers on why it would do that. I did some searching and came across a posting on adjusting the TV Cable(Throttle Valve). So today opened the hood took 2 seconds and it was done. Drove it around the block and WOW night and day. 1-2 works 3 works and it doesn't stay in OD. Push on the pedal just a little and it smoothly shifts down.
So anyone that hasn't checked/adjusted the cable or anyone that is having weird tranny problems Adjust that cable first.
How to from Alldata:
1. Shift transmission into Park, shut engine off and raise hood.
2. Press cable release button.
3.Push cable conduit back into cable sheath as far as possible.
4.Rotate lever on throttle body to wide open throttle position. Cable will ratchet to correct adjustment point as lever is rotated.
Super easy and worth checking. Sorry if this is in the wrong area.
Old November 23rd, 2009, 17:34
dgrigorenko's Avatar
dgrigorenko dgrigorenko is offline
Re: Anyone that hasn't adjusted there Throttle Valve cable do it. WOW.
interesting... i will have to try it out, since i drop to OD at 40 with 4.56's on 33's. t
thanks!!!
Old November 23rd, 2009, 17:36
thechief86's Avatar
thechief86 thechief86 is offline
ooh! i'm gonna go try that! mine stays in overdrive, then i hafta floor it to get it to downshift to make it up hills. i bet this will fix it! what year is your jeep?
Old November 23rd, 2009, 17:39
This was done on my 1990 4.0.. hope this helps others too. Was something I never thought of and took a lot of reading to accidentally run into it, lol.
Old November 23rd, 2009, 17:45
thechief86's Avatar
hmmm.... mine's an 89, i wonder if it's the same between the 2 yrs?
Yes 89 should be the same.
Old November 23rd, 2009, 17:50
thechief86's Avatar
ahhh, i figured it oot. now to test drive...
Old November 23rd, 2009, 17:54
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Wel.. the 1-2 shift is computer controlled and does nto usually engage til something like 45-4800 rpm.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old November 23rd, 2009, 17:58
dirts4racin2's Avatar
dirts4racin2 dirts4racin2 is offline
I just ran out and did this on my 88' and wow what a differance! Thanks for the info.
Old November 23rd, 2009, 18:00
That what i was told months ago, so I tryed revving it out a few times and still no shift. Now it shifts into second just like it normally would.
Some may not have as good of results as I did as mine was about a half inch out of adjustment.
Old November 23rd, 2009, 18:01
Awesome. Glad it helped you too. Its something so simple but I haven't seen it posted as a how to.
Old November 23rd, 2009, 18:05
thechief86's Avatar
ha! it made quite a difference on mine as well! i had problems going up hills, to where i had to floor it to make it down shift, and now, i just barely hit the gas, and it acts how i want it to. good stuff! thanks for posting this!
Old November 23rd, 2009, 18:08
No Problem. Just my first attempt at helping rather than being helped on this forum..
Old November 23rd, 2009, 18:12
dude! this was nice!!! i just did it, and it took all the slack out of my pedal and made everything smoother. it was out of adjustment by probably3/8 inch.
definatly a helpful post
Old November 23rd, 2009, 18:14
Did you do this on a 99?
throttle cable help bluejeepkid OEM Tech Discussion 7 August 21st, 2009 18:58
WTB kickdown cable/throttle cable bracket for 2000 intake Skullver SoCal For Sale 2 January 21st, 2009 17:12
Throttle Cable Rando89 Modified Tech Discussion 3 December 8th, 2008 11:28
throttle valve cable wacky OEM Tech Discussion 9 May 12th, 2008 18:33
throttle cable 91Limited OEM Tech Discussion 6 April 15th, 2006 22:49
