| North Atlantic Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums. |
Thread Tools | Rate Thread | Display Modes |
#31
Re: My slooooowwwwww build thread :)
Today I will most likely pull the battery and alternator and bring to to the parts store for testing.
edit: I'm going to drive my jeep to the auto parts place right by me (Car port) to have them battery/alternator tested. The battery was on charge all night. I am pretty sure my battery is fine. Last edited by hupo224; 11-14-2009 at 06:06. |
#33
Alternator is bad.
Let's see how today turns out. Going to pull the alternator and the junkyard said they will replace it. Last edited by hupo224; 11-14-2009 at 07:27. |
#34
Old alternator / fork for getting that ZJ tie rod end I left at the junkyard
![]() ZOMG I FINALLY DID IT!??! ![]() ![]() Just got back from the junkyard. I wish there was more/better U pulls around. This place is always swampy and hard to navigate. I had to ask them to move a cherokee for me. I pulled an alternator out of a 91 and I got the zj tie rod end. (Didn't pay a cent being that I traded my bad alternator in and they owed me that tie rod end lol) Going to throw the alt in now. |
#35
Holy freakin crap.
So I got the alternator in and I took it for a test drive. Seems to be charging fine and my steering feels a lot more solid now. What happened? Well I have to say I drove no more than 2 miles. I shifted to neutral (auto trans) and turned the key off while rolling. I went to start it again and NOTHING. So I had to roll in front of someones house. Where it is at right now (They let me park it there). If you notice in the first post I had a engine code. Something to do with the TCM. Here is exactly how it feels. I turn my key on. Lights gauges everything engages fine. As if the battery is fully charged (which it is) when I turn the ignition on I get absolutely nothing. No clicks or anything. It feels as if I am in drive or something other than park or neutral and trying to start it. I tried moving the shifter back and forth to see if it would help. But same deal. I disconnected my battery for a couple of minutes and reconnected and still the same problem. Please help my mosey ![]() Also I should mention that I rushed a little in the end of throwing the alt in. Although everything is connected right. My battery was sitting without being strapped down. And the one "long" bolt that comes out of the battery tray may have fell onto the positive terminal. I'm not sure if this actually happened. But it is something to consider I suppose. |
#36
smack your starter with hammer. solenoid may be stuck
99 XJ, 7.5", BDS Longarm, 35" KM2's, Beadlocks, OTK Steering, Anti Rock, Hydro Assist, Built D30, C8.25, 4:56s, Lockers. |
#37
Hm. I tried tapping it with a big screw driver with the guy. But seemed to not do anything. I suppose tomorrow morning I can try the hammer. For the meantime. Any other suggestions I can pile up? Fuel pump kicks in and everything. Radio shuts off as if it is trying to start. But not a thing.
#38
battery have a good ground?
#39
Yeah I double checked it. It seems that everything is powered correctly.
(I wish to steal your sunday, you should come over lol )
#40
starter relay possibly?
#41
IMO it takes more then a big screwdriver to tap the starter... use a hammer
94 2dr country. 3.5 RE.. 31's...Friends of Matt #19 |
#42
Starter relay. How are you supposed to check whether it is good or not? I pulled it out and realized wow I cant check to see if it is bad. Then threw it back in. I will try a hammer tomorrow. But it just doesnt make sense that the starter suddenly took a crap (which skreed, thank you again for it) as it started just fine when I put everything back in.
I found this thread (http://www.naxja.org/forum/showthrea...ighlight=start) Which seems to link to the NSS. Blah. Let's pick minds. |
#43
I'm quoting this from that nss thread
jump the starter get a long piece of wire or u can use yur jumper cables....clip and end to the post on the starter that the battery cable goes to then touch yur pos batt terminal.....if it starts its most likely the relay.
#45
I will do that tomorrow most likely. Right now we are going to chain it and pull it home. As it is only a few blocks away.
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
| Thread | Thread Starter | Forum | Replies | Last Post |
| ftw or fml build thread | toyotawrench | SoCal Chapter | 31 | 10-24-2009 18:57 |
| my build thread | shawnxj | Red River Chapter | 4 | 05-10-2009 08:28 |
| My Very Own Build Thread! | Darky | Modified Tech Discussion | 25 | 04-10-2009 21:17 |
| Not quite a build thread... yet. | MnGrnXJ | South East Chapter | 28 | 04-03-2009 13:09 |
| The build thread | DutchVDub | Colorado Chapter | 101 | 03-15-2009 09:25 |
