Old September 7th, 2003, 16:55
shizza-my-nizza's Avatar
shizza-my-nizza shizza-my-nizza is offline
NAXJA Member #671
front driveshaft problems
I just installed RE drop brackets, superflex fixed lower and superflex udjustable upper control arms on my 01, 5 speed, 231 xj. I also swapped in a 96 high pinnion D30 and Skyjacker 6" coils. My problem is that now my factory front driveshaft is not even long enough to install. Are there any factory front driveshafts that would be long enough for my application?
TIA, Eric
Old September 7th, 2003, 17:01
RCP Phx RCP Phx is offline
Look at one from an auto,mine measures about 32" c to c.
Old September 7th, 2003, 17:34
NAXJA Member #671
Is that a colapsed or extended measurement?
Old September 7th, 2003, 17:38
Thats at the middle of comp/ext !!
Old September 7th, 2003, 20:10
NAXJA Member #671
Thanks, I will be getting an auto driveshaft. I measured my driveshaft and fully extended it only measured about 31"
Old September 8th, 2003, 00:20
azxjman's Avatar
azxjman azxjman is offline
You could always just get it retubed mine only cost 75 bucks and the local bone yard wanted 100 for the one out of a grand cherokee which would have worked perfectly.
Front Driveshaft Rebiuld $$$?? cherokee89 OEM Tech Discussion 10 December 10th, 2003 15:04
problems with new front springs JJ13 Modified Tech Discussion 7 July 20th, 2003 22:24
farmermatt, driveshaft problems!!! atowley Modified Tech Discussion 5 July 3rd, 2003 20:06
Front driveshaft rebuild questions woody Modified Tech Discussion 4 June 3rd, 2003 11:50
Front driveshaft compression travel available? SV1CEC Modified Tech Discussion 5 April 9th, 2003 23:13
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
