Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Frequently Asked Questions and Writeups
Frequently Asked Questions and Writeups FAQ topics on common and frequently posted issues. No posting or replies allowed.
Old October 25th, 2006, 09:27
Roxtar's Avatar
Roxtar Roxtar is offline
What gear ratio do I want?
Deciding what gear ratio to use when changing tire size is actually quite simple.
It's just a matter of mathematics.
Current tire size/new tire size =current gear ratio/new gear ratio
This simple formula will allow you to figure out what ratio will get you back to your current performance.
For instance, let's say you have stock 3.55 gears & stock tires and want to go to 33" tires.
Stock XJ tires are about 27" tall so:
27/33 = 3.55/new gear ratio
Cross multiplying (thought you'd never use algebra again?) gets you this:
33 X 3.55 = 27 X new gear ratio
117.15 = 27 X new gear ratio
117.15/27 = 4.34
IOW, 4.56 gears (the closest avail to 4.34) will give you slightly lower gearing than you had while stock.
From here it's up to you where to go.
If stock performance is fine stay with 4.56. If you want a little more low end grunt, go to 4.88. If you want to murder the rocks go to 5.13 or lower.
BTW, lower gears = higher numerically.
gear ratio for a d 35 stu's jeep's OEM Tech Discussion 8 December 20th, 2007 18:58
Gear ratio 94LT1Z OEM Tech Discussion 3 December 31st, 2005 19:54
What Gear Ratio comancheon33 OEM Tech Discussion 7 May 9th, 2005 21:42
Gear Ratio Help speedn431 Modified Tech Discussion 4 May 14th, 2004 11:48
gear ratio john Modified Tech Discussion 6 July 8th, 2003 15:13
