Old October 26th, 2009, 21:04
johnsoninc86's Avatar
johnsoninc86 johnsoninc86 is offline
Keep blowing fuse #11- run/start ignition, daytime running lights
Just like the title says, I keep blowing fuse #11 in the kick panel fuse box. It only does it on hard right turns though. When it started doing it, it would just stall the jeep on the turn, then it would restart itself and keep running. Now, it stalls the jeep, pops the fuse, and pops every replacement fuse that I throw at it. I know that I'm just going to have to trace the wires and find the short, but I was wondering if anyone had any idea on where I should start? What all does this circuit power? Anyone else have a problem blowing this fuse?
I was also wondering if maybe a bad ignition switch could cause this problem? Thanks for the help guys.
park lights keep blowing the fuse hidesintrees OEM Tech Discussion 9 September 23rd, 2009 07:13
DRL's on your US XJ (Daytime Running Lights) Secshunate Modified Tech Discussion 7 October 25th, 2007 19:18
daytime running lights module PolishX Wanted: Private Party Only 0 November 14th, 2006 08:45
Daytime running lights?? sys_eng OEM Tech Discussion 21 January 18th, 2006 05:45
IPF harness + daytime running lights Gjeep Modified Tech Discussion 1 October 24th, 2004 23:09
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
