Old October 26th, 2009, 10:44
FlexdXJ's Avatar
FlexdXJ FlexdXJ is offline
Code question
I went to the auto parts store to use the OBDII scanner and got a Cylinder 3 misfire detected code. Would this be a sign that I may have a cracked header? I got some heat soak while wheeling last weekend if that helps.
97 XJ, OME, JCR, HDOR "HObrid" cage blah blah blah... DD/trail rig, '66 M416 expo/truckbed trailer, 02 Subaru WRX wagon
[QUOTE=*89Laredo*;246072645]
The human skull makes quite a loud noise when it hits a metal chair.
[/QUOTE]
Old October 26th, 2009, 12:25
joe_peters joe_peters is offline
Re: Code question
Basic info required: year/engine/etc.
Just a guess yours is a late model with the heat soak problem.
Old October 26th, 2009, 14:28
FlexdXJ's Avatar
Re: Code question
There is like a 99% chance its a late model when I used an OBDII scanner too. DUH!
97 4.0 AW4 stock engine and drivetrain. You'll have to forgive me I've been awake since 2 this morning!
[/QUOTE]
Old October 26th, 2009, 17:17
Re: Code question
Ok.
A 97 would be a bit early for the heat soak issue, it mostly hits the later years w/o fuel return and with the newer manifolds.
Pull the plugs and post up their condition. I would suspect the intake more than a header.
Trouble code question FlexdXJ OEM Tech Discussion 10 June 12th, 2009 05:58
E-Code Question Cherokeekid88 Modified Tech Discussion 5 January 28th, 2009 19:07
'01 no start/code question blaisetd OEM Tech Discussion 13 September 12th, 2006 13:04
98xj 4.0L high idle question code question rapom OEM Tech Discussion 4 June 27th, 2005 16:18
code question? HilltopXJ OEM Tech Discussion 4 May 26th, 2005 21:46
