Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Frequently Asked Questions and Writeups
Frequently Asked Questions and Writeups FAQ topics on common and frequently posted issues. No posting or replies allowed.
Old October 23rd, 2006, 18:21
Goatman's Avatar
Goatman Goatman is offline
Do I really need my sway bars?
It is pretty universally accepted that the rear sway bar is unnecessary, so it can be removed with little or no consequence. There will be a slight improvement in rear articulation with the rear sway bar removed.
It's a different story with the front sway bar. There are dramatically different experiences between owners of various rigs concerneing how their rigs handle with no front sway bar. How well a rig drives without a front sway bar is totally dependant on the suspension of that particular vehicle. With stiff enough springs and the right shocks it can drive well and be safe with no sway bar. However, if the springs and/or shocks are softer the rig can lean excessively in the corners or in quick avoidance type manuevers, and using the front sway bar would improve the handling and the safety. Generally, it seems that rigs with stiffer coils, like Rancho's or Skyjackers, and/or with stiff rear springs (like BOR or a bunch of add-a-leaves) do much better without the front sway bar.
We can look at it this way.....many rigs need a front sway bar, most are better off with a sway bar, and some handle well without one. It's important for each driver to be realistic and honest with themselves about the handling of their rig without the front sway bar, so use good judgement and be safe. There are some good sway bar disconnects on the market, and it is very easy to make your own quick disconnects by simply using a 10mm wing nut on the top of stock links, so running a front sway bar on the street is an easy thing to do. Since handling relates to safety, it is a good idea to take a conservative approach to running with or without the front sway bar.
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
no sway bars? SeansXJ Modified Tech Discussion 34 October 27th, 2006 04:22
What should I do with my sway bars? motrctyman Modified Tech Discussion 17 December 28th, 2003 11:28
Sway Bars ec_3000 Modified Tech Discussion 29 October 22nd, 2003 10:14
How many of you have no sway bars? Speed_racer Modified Tech Discussion 45 October 17th, 2003 18:10
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
