Old October 9th, 2009, 05:54
Dave Meyers's Avatar
Dave Meyers Dave Meyers is offline
no heat - solved
Had a coolant leak so replaced water pump and thermostat while I was at it. Still had a leak and found the problem was the radiator, so I replaced the radiator. No more leak, but no more heat either. Could only get heat into the truck if I let it idle for a long time. Driving would eliminate the heat and it would blow cold. I determined it was a thermostat problem, so I dug through my garbage for the box it came in. It was the right temp, but a "fail safe" t stat. So, wfter replacing the pump and t stat, with the bad radiator, it still overheated and that tripped the fail safe t stat into locked open position, thus, no heat. I just need to replace the t stat and all will be fine. I didn't know I had bought a fail safe, didnt even know what it was till I saw the box. Thought I would share this.
Dave
Old October 9th, 2009, 06:24
winterbeater's Avatar
winterbeater winterbeater is offline
Re: no heat - solved
I thought that fail safe meant that if it went bad, it would break in the open position. It does not mean that if it overheats once, it locks into open. It should still close when cooled down. That said, I have heard about tstats being ruined by being overheated. Normally, however, that is not the case.
Old October 9th, 2009, 07:36
ehall's Avatar
ehall ehall is offline
sounds to me like the blend door is flapping
my '91 beater rebuild
Old October 9th, 2009, 08:58
The truck over heated after the install of the new T stat cuz the radiator was still bad. I should have replaced the T stat after the that over heating incident. The box says that it breaks in the open position, so you can limp home to repair it without over heating. It is also self-described as one -use only. It also says once it does that, it needs to be replaced cuz it won't close. I am not going to get another one. I'll use the standard kind. Wish I realized which one I bought at the time. you live and learn.
Old October 9th, 2009, 09:45
I checked that out, too. All is fine. Other tell tale symptom is slow to warm up, and never gets close to running temperature. My guess is 140 or so degrees, unless I let it idle without pulling air thru the radiator, then gets warmer and can get some heat.
Old October 9th, 2009, 09:51
Stant makes a deluxe model. It's only like $6 or $8. It looks like the best bet to me.
Old October 9th, 2009, 10:17
Agreed.
Old October 9th, 2009, 10:38
ehall's Avatar
yeap tstat is stuck
Old October 11th, 2009, 16:00
Yup, removed the single-use fail safe tstat, it was locked open I installed a stock replacement. Heat works well, no coolant or tranny fluid leaks. Just in time, it is getting cold in Wiscsonsin, need heat in the truck, and don't want to wrench on it in the cold.
engine's hot, but no heat, then heat, then no heat tstaples OEM Tech Discussion 18 November 20th, 2007 10:23
thanks guys .... problem solved sandandsurf OEM Tech Discussion 3 January 25th, 2007 10:33
prob solved ChevelleSSLS6 User Support, Questions and Suggestions 0 January 7th, 2007 23:19
'91 XJ HO NO SPARK SOLVED TXRIVERRAT OEM Tech Discussion 19 December 18th, 2006 21:15
Overheating is not solved robs Modified Tech Discussion 64 July 3rd, 2005 17:02
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
