Old September 15th, 2009, 16:34
curtis1620 curtis1620 is offline
Belt Tensioner on 94 XJ 4.0
I bought my 94 XJ 4.0 used. The guy I bought it from mentioned that the belt tensioner had broken off, however it was still adjustable by prying on the power steering pump. I'm guessing the tensioner somehow adjusted the position of the power steering pulley to tighten or loosen the belt.
I now have a loose belt and would like to replace the tensioner, however I can't find it anywhere. The guy at my local jeep dealer was unable to find the part and said there was no tensioner on this model. Can't find any in the local junkyards.
Can anyone help me out here? Part number? Will a new power steering bracket have the tensioner? Was there a tensioner to begin with?
Thank you for your help!
Old September 15th, 2009, 16:50
wolfpackjeeper's Avatar
wolfpackjeeper wolfpackjeeper is offline
Re: Belt Tensioner on 94 XJ 4.0
the power steering pump bracket is the tensioner. it is a screw drive. basically you loosen the pump bolt, loosen the carriage bolt and ratchet on the assembly adjuster that runs under the pump.
you need the whole thing
Old September 15th, 2009, 18:17
Thank you. Not having any luck finding the part on-line. Anyone know of a place I can find one other then the dealer?
Old September 15th, 2009, 18:42
any old pick a part should have it. If it is a cherokee made before 1997 it has the tensioner/ps bracket you need. The guy is just to lazy to go pull a part that he will not make much on.
Go to a junkyard and grab it yourself, should not take too long, and it will be cheaper. I actually need one to get my MJ converted to power steering. The local yards around here have several.
Old September 15th, 2009, 19:19
heyhar's Avatar
heyhar heyhar is offline
'95 and down (to '91?) is what you need to look for. Our two '96s have the newer style, which I prefer, by the way. But I don't know if it's a dead swap, as things changed in '96.
Old September 15th, 2009, 20:35
Pelican Pelican is offline
NAXJA Member #1191
The bracket is adjusted with a long screw with the head pointing toward the airbox. It is a lot easier to see how this all fits together if you remove the airbox which only takes a couple of minutes. The most likely broken part is the adjusting screw and the easiest way to break that is by not first loosening all the bolts that secure the power steering bracket before you start adjusting the belt tension. It's been a while since I did this but I believe there are two in back and one in front plus the pivot screw. These can be gotten to from above with the proper open-end wrench although some go at the back bolts from below.
This came up in a thread some time ago where a student in Boston without a lot of time to go rummaging through the yards tried to find the adjusting bolt. I don't know where all he looked but know he didn't find one in the allotted time. He ended up using the "crowbar" method mentioned above and was able to get the thing sufficiently tight to drive. I personally wouldn't really trust that for any great length of time.
Old September 15th, 2009, 21:32
I have owned and worked on cars where the belt was tensioned like this oem. There was even a nice spot on the block to lever the prybar against.
I am not saying there are no better ways, but there is nothing unsafe or untrustworthy about it.
Old September 16th, 2009, 07:36
NAXJA Member #1191
My '85 2.5L XJ was tensioned with the prybar method (with the alternator bracket). However, it was designed for this with a long adjustment slot and a large headed snubbing bolt facing forward.
The 4.0 is a completely different beast but I admit that I have no experience with attempting to properly tension the belt and maintaining that tension without the adjusting screw, so will withdraw my statement about not trusting this as an alternative setup.
Old September 16th, 2009, 11:27
right, usually they are slotted. Properly done though the tension screw plays only a very small part in holding the tension, the three bracket bolts should be holding most of it.
Either way, since it was designed to use the tensioning screw to set it I would use it.
Old September 16th, 2009, 12:11
comanche91's Avatar
comanche91 comanche91 is offline
All these p/s bracket parts are still available from the dealer. You probably only need the long adjustment bolt #8, p/n 34202480. But the yard is probably your best bet.
Serp belt tensioner bhansen99xj OEM Tech Discussion 4 June 6th, 2008 16:31
99 belt tensioner on 93 XJ czb83 Modified Tech Discussion 3 May 19th, 2008 13:30
Belt Tensioner JeepCherokee OEM Tech Discussion 2 June 20th, 2006 22:31
belt tensioner bolt... dizzymac OEM Tech Discussion 5 August 5th, 2005 17:10
belt tensioner jeep_cj8 OEM Tech Discussion 3 July 11th, 2003 09:54
