Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old October 30th, 2015, 14:49
fzsk4p fzsk4p is offline
ECM controlled E. Fans Temp Set Points
Sent Chris Jensen a couple XJ ECM`s to recal for my Stroker YJ.
Been running a mechanical fan but MIGHT convert to a Ford Contour electric.
What are the XJ aux. fan temp set points that are cal-ed in the factory XJ ECM ?
Thinking on at 205 and off at 195 ? Chris can cal anything I want.
Thanks
Old October 30th, 2015, 15:48
ehall's Avatar
ehall ehall is offline
Re: ECM controlled E. Fans Temp Set Points
Normal temp is 210. The condenser fan is set to come on around 220 (+/- 5) depending on the year and features (some are more tightly integrated into AC than others). My efan setup uses a switch that turns the fan on at 95c (203f) and then off again at 90c (194f). That is hotter than the thermostat, so the idea is that coolant gets hot enough to open the thermostat all the way the fan will come on, if it gets any hotter the condenser fan will kick on to support it, then when coolant from the radiator drops the engine temp enough for thermostat to close the fans turn off.
my '91 beater rebuild
Old October 30th, 2015, 16:04
This is the logic I am thinking also. Don`t want to be running at 195 as the fan will never shut off during normal operation.
Best numbers on the dyno are hot lapping at around 210. So I am not afraid of a little heat so long as the fan can take it down when requested.
Old October 30th, 2015, 16:32
ehall's Avatar
This is my setup http://www.naxja.org/forum/showthread.php?t=1035194
Old October 30th, 2015, 16:54
Perfect, suspect the fan combo you are using is in the 3.8 dual unit that will fit the YJ radiator nicely. Can use the ECM to trigger the relay. Have to decide if a single speed will suffice or wire it up for the dual low/high.
Thanks
Rate This Thread:
Dual Electric Engine Fans - 11" fans - 12V - 2 speeds BigTP2 For Sale: Private Party Only. XJ ITEMS ONLY 3 December 19th, 2006 12:59
What does a Dem controlled House and Senate mean to you? SBrad001 Non-Tech / Off Topic 45 November 11th, 2006 07:58
WTB: Front tow points / rear hitch or tow points orchimaxi Wanted: Private Party Only 0 May 20th, 2006 08:08
OMG! I want one! Remote controlled R1! mdl Non-Tech / Off Topic 8 April 16th, 2006 21:01
Grounding Points?? Positive Points?? XJ91 Modified Tech Discussion 1 May 30th, 2004 20:47
