Old August 17th, 2009, 12:31
muddeprived muddeprived is offline
what's the thickest oil weight to run?
I got a rear main seal leak. It gets kinda bad when i'm cruising on the freeway at 65 mph and whenever the jeep is warmed up. I have a trail ride coming up this weekend and don't have time to fix the seal so I'm thinking of running thicker oil just until I can fix it next week or so. What's the thickest engine oil I can run in the jeep to maybe reduce the leak? Is there any quality additives I can toss in there to reduce it?
I run 5w-30 year round.
Old August 17th, 2009, 12:42
dagr8tim's Avatar
dagr8tim dagr8tim is offline
Re: what's the thickest oil weight to run?
I've read that some guys run 15w40.
Old August 17th, 2009, 12:45
old_man's Avatar
old_man old_man is offline
Put in about a cup of lacquer thinner in the oil. It will soften and swell the seals. There are off the shelf additives available as well, but they use the same stuff/concept.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old August 17th, 2009, 12:47
what are some other shelf additives?
Old August 17th, 2009, 12:48
TunaSoda's Avatar
TunaSoda TunaSoda is offline
The first # is the cold viscosity (thickness at startup)
The second # is the hot viscosity (running temp thickness)
15w40 is not much thicker than 5w30 when warmed up
Old August 17th, 2009, 12:49
XJ Stryker's Avatar
XJ Stryker XJ Stryker is offline
WHO DAT!
Hey Mudd I run Rotella 15-40 in both my rigs. It is a diesel oil but it is better for my engine.
You will have no problem running 15w40.
Old August 17th, 2009, 13:02
ehall's Avatar
ehall ehall is offline
I have used 1qt of 20w50 as a thickener works fine. If you want more than that put half a quart of Lucas stabilizer in there.
my '91 beater rebuild
Old August 17th, 2009, 13:03
Thanks guys. What about 20w-50? I saw this available with all the other oil weights. That should be thicker.
Old August 17th, 2009, 13:20
wolfpackjeeper's Avatar
wolfpackjeeper wolfpackjeeper is offline
When I worked parts I saw a couple guys try to fix a leak in their ford van with 80-140 gear oil. They dumped 6 quarts in and actually made it to the end of the parking lot before the truck quit for good.
15-40 diesel like Rotella is a good choice, and about as thick as I would go. At one point you will start to tax your pump's abilities to push it through the passageways, and the oils ability to lubricate the bearings in the crank journals.
Old August 17th, 2009, 13:40
The thick oil won't be in there long enough to do any harm. It'll be out next week or so when I do the rear main.
Do you think Lucas oil stabilizer will help? I've been recommended this by a couple of people here and at the shop. They said it works well in reducing leaks.
Old August 17th, 2009, 13:44
CanMan's Avatar
CanMan CanMan is offline
I used it in my old rig with 220k on the clock. Still ran great without any more excess leaks or smoke at 240k.
During the winter id use 10w-30 though, but if you live in an always warm climate I wouldnt worry about it.
Old August 17th, 2009, 13:50
TunaSoda's Avatar
5w50 would be awesome
Old August 17th, 2009, 15:21
I like the lucas oil stabilizer. Some people blast it, and try to cite some testing sites, but from what i have seen most of the sites blasting it are running biased or false tests, and are funded by a major competitor.
Old August 17th, 2009, 18:37
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
I currently run 20w-50, she purrs like a kitten.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old August 17th, 2009, 18:55
lawsoncl lawsoncl is offline
It motor oil terms thats more like a 40W-60 motor oil. Hot would have probably been okay, but they probably pretzeled the oil pump shaft trying to pump that cold.
Sprung weight vs Unsprung weight.... Ghost Advanced Fabrication and Engineering 14 October 24th, 2006 13:23
weight of a 44 AJPulley OEM Tech Discussion 6 January 23rd, 2006 17:48
How much does a D30 weight? Angus OEM Tech Discussion 1 November 8th, 2005 19:39
4.0 weight jlake1 OEM Tech Discussion 2 November 30th, 2004 08:04
BFG weight? logdog Modified Tech Discussion 2 May 20th, 2004 22:10
