Old August 8th, 2009, 11:32
gw204 gw204 is offline
Blower motor stopped working...
Was flushing out the cooling system in my '00 this afternoon by disconnecting the top radiator hose (ran it to a bucket) and filling the radiator via the cap while the engine was running. I had the heater on high while I was doing this and when I shut the Jeep down I noticed it was no longer blowing any air. It won't blow on any setting. High, low, A/C, heat, defrost... So, I started checking fuses thinking I may have gotten something wet but they all seem to be fine. I don't think it was a failure of the motor itself as it never gave any signs of going out. I found reference to the resistor, and how the fan should still work on high so I don't think it's that either.
I did get overflow from the radiator fill port and some from the inlet on the pass side, but I didn't see any electrical components in the path of that water. I think I also splashed some on the connectors against the inner fender by the air box, but it wasn't a lot.
Any ideas? I'm going to pull the blower and check it next...
Thanks.
Old August 8th, 2009, 11:44
AIbandit's Avatar
AIbandit AIbandit is offline
Re: Blower motor stopped working...
Just jump the blower motor. Or use a test light. The blower motor switches are VERY prone to giving up the ghost. They also sometimes result in cool jeep fireballs.
Old August 8th, 2009, 14:08
winterbeater's Avatar
winterbeater winterbeater is offline
x2, test for voltage at the blower plug. Motors don't usually just quit. They blow fuses or the resistor.
Old August 8th, 2009, 15:11
Thanks for the suggestions guys. Dumb question though... Where the heck is the plug? I looked for it for a minute or two, but came up empty.
Old August 8th, 2009, 15:32
You can see the motor in the firewall under the hood, right. Follow the wire. It's probably only 6" or so long.
Old August 8th, 2009, 16:57
Got the wire, but it tucks behind the firewall and there's pretty much no slack on it ,and no connector is accessible. Any chance I can get to it by removing the wiper cowling?
Old August 8th, 2009, 17:01
AIbandit's Avatar
Lol? they should come out of the firewall... anywho god made test lights with sharp tips to do cool things like poke insulation.
Old August 8th, 2009, 17:10
Guess I need to get one of those tomorrow...
Old August 8th, 2009, 17:16
Looking in the 2000 FSM, the plug is right there on the motor. There is actually no wire out of the motor. The wire plugs into the motor right at the motor. Hopefully you can uplug that. Hope the motor is good. THe FSM says you need to evacuate the system and remove the accumulator / dryer to get the blower motor out.
Old August 8th, 2009, 18:05
Got the plug out...what a PIA. Thanks winterbeater!
Looks like I'm not getting power to the blower motor. What to check next? Recheck the fuses and get a look at that resistor?
Old August 8th, 2009, 18:18
AIbandit's Avatar
pull ur HVAC controls out of the dash and see if the plug for the switch is burnt Odds are it is. Every one I have seen is burnt or melted. At junk yards there either burnt melted or gone.
Old August 8th, 2009, 18:41
All the plugs look good. I can hear the system try and change functions when I move the middle switch. I verified power in the connector for the fan speed switch and will try to jump the fan via that connector tomorrow once I get the fan connector plugged back in. Access to that connector is nearly impossible. Whomever laid that out should be shot...
Old August 8th, 2009, 18:45
By the way...thanks for all your help guys. I really appreciate it!
Old August 8th, 2009, 19:03
AIbandit's Avatar
Your welcome I'm not sure whats next on the 00
Did you test light the switch? the fuse? you might have to trace it from the switch until you find where there's no juice. might have fuse-able links somewhere
Old August 8th, 2009, 22:45
Just keep tracing down the line for the high speed fan, as that bypasses the resistor. Are you SURE the fuse is good. Have you popped it out to look at it. The reason I push this it that I had one of those LED fuse testers that came free in an assort of fuses that told me the fuse was good. Two weeks later, I figured out that it was actually burnt, but a small back current in the system tricked it. Checking with a voltmeter showed me that I had 12 V on one side of the fuse and 1.5 on the other.
AC/Heater Blower stopped working youngbuck98xj OEM Tech Discussion 17 November 11th, 2007 13:50
A/C Stopped Working aznightkrawler OEM Tech Discussion 3 July 23rd, 2007 20:32
Blower motor not working. replaced motor and resistor...Searched can you help? 99xjclassic OEM Tech Discussion 12 May 4th, 2007 22:31
low beams stopped working XgeekstarX OEM Tech Discussion 6 December 6th, 2006 08:47
Blower motor stopped working tnxj OEM Tech Discussion 13 December 13th, 2005 21:26
