Old October 12th, 2006, 19:14
northernlightsfive northernlightsfive is offline
Trailer lights work fine as long as lights are not on.
Got an interesting problem (couldn't find anything when I searched). I installed a Hoppy trailer wiring kit on my 99 (ordered the wiring from advanced auto). I installed the kit with no problem, the blinkers and the brake lights work on the trailer, but as soon as I turn the head lights on, none of the lights work on the trailer (all work fine on the cherokee). When I turn the head lights off, everything works correctly. I have even bought a new wiring harness for the trailer and no luck. I have also tried grounding the trailer frame directly to the body of the cherokee and still the same symptons. The trailer is from Harbor Freight and the lights in the back have two brown and one yellow/green (depending on side) down each side. The instructions say to connect the two brown to the one brown of the wiring kit and the yellow/green to yellow/green wire. I have even made sure there is a good fuse in the tow package spot (not sure if that would help or not). Has anyone ever had the same problem before?
Old October 12th, 2006, 19:58
Rev Den Rev Den is offline
Re: Trailer lights work fine as long as lights are not on.
Yup.
Run a ground wire from one of the mounting bolts on both the lights, to the ground on the plug.
Rev
Old October 13th, 2006, 16:05
Talking Re: Trailer lights work fine as long as lights are not on.
Rev,
You ROCK! It worked. Thanks so much! I am moving this weekend back to your area (Chicago) and didn't want to make the trip with out proper lights.
Old October 13th, 2006, 16:13
Glad I could help....and yup...don't wanna run through TN without trailer lights.
Rev
Trailer Wiring and Parking lights issue northernlightsfive OEM Tech Discussion 8 April 12th, 2007 12:52
WANTED: MJ tail lights for trailer build SOILARZ Sierra Chapter 0 September 25th, 2006 21:51
Wiring for Trailer lights tgregg OEM Tech Discussion 8 April 13th, 2006 14:27
trailer lights on an 89 jeepin_al OEM Tech Discussion 9 April 30th, 2005 09:13
trailer lights low_life OEM Tech Discussion 5 April 17th, 2004 15:20
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
