Old January 12th, 2018, 19:17
HttpWayne HttpWayne is offline
Re: AW4 whining noise
Just speculating, but one of the previous persons mentioned he had a transmission flush and he suspected the torque converter. Do transmissions flushes effectively clean out the torque converter? It might be worth the effort to pull the transmission to get that guy cleaned out if you have a transmission flush done. It doesn't seem like it gets good fluid flow by design and after a few decades and a few flushes, assuming it had them like it was supposed to, it probably has very old fluid in it.
Unless they do actually participate very well in the flush. Then nothing I said even matters
Old January 20th, 2018, 11:33
MG2000XJ's Avatar
MG2000XJ MG2000XJ is offline
Paying attention to this as well. Mine has developed a whine recently and the shop immediately said, rebuild it. Same symptoms, same whine, same bellhousing area. Lots of comments say just swap in the lowest mileage aw4 you can find. If I come up with an answer I will report back.
whining noise... Robs92XJ OEM Tech Discussion 3 June 21st, 2008 13:13
Whining Noise?????? sprngfldxj OEM Tech Discussion 6 February 2nd, 2007 22:07
whining noise Mikel OEM Tech Discussion 5 March 11th, 2006 13:04
Whining noise from motor jeepboy12001 OEM Tech Discussion 7 September 16th, 2005 21:43
whining noise, need help ASAP CStamm OEM Tech Discussion 7 October 20th, 2003 14:26
