Old January 10th, 2018, 19:44
CWolfe CWolfe is offline
PCV/CCV replacement lines
So I decided to replace my PCV and CCV grommets and elbows, and in doing so I cracked the CCV line in half. Sourcing the grommets and elbows was no problem, but I’m having a really difficult time finding anyone that sells the lines that run to the intake manifold and the air box...curious as to where everyone’s finding these parts? (96 XJ, 4.0 I6, NP231) Any assistance is much appreciated.
Old January 10th, 2018, 20:09
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Re: PCV/CCV replacement lines
www.teamcherokee.com they had them for my 96
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old January 11th, 2018, 01:30
Ralph77 Ralph77 is offline
I replaced a couple of mine with ones from the boneyard. I don't see why you can run some hose instead. Might even be a better idea.
Old January 11th, 2018, 05:04
Ralph:
I'm not the original owner, but I'm pretty sure all of the PCV/CCV components and lines were original to the vehicle which probably explains why they were all so brittle. I could check the local yard but I'm afraid I might run into the same problem there...what has your experience been trying to salvage parts like this from a junkyard?
Wayne:
I appreciate the link. I'll try to get in touch with them today to check their availability. I see they sell them with the elbows and grommets, or just by themselves.
Thanks to both of you for your replies.
Old January 11th, 2018, 11:54
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
eBay used to have CCV sets with the lines. If you can find the part # or just do a search you’ll probably find a few dealers on eBay with the lines.
Old January 11th, 2018, 14:06
Originally Posted by CWolfe View Post
Ralph:
Wayne:
No problem but my Jeep is an '00 so I was stealing them out of '97's to '01's. Thinking a little newer then the '96 and down that you would need. Assuming there is a difference between the 2
Replacement Fuel Lines bjoehandley OEM Tech Discussion 7 January 11th, 2018 21:06
Replacement Vacuum lines Renegade XJ SoCal Chapter 3 November 14th, 2012 15:56
replacement trans lines BenDiesel OEM Tech Discussion 5 March 18th, 2010 10:29
Replacement vacuum lines RollTider OEM Tech Discussion 9 August 27th, 2009 06:27
Plugging the AT lines in replacement radiator Gold Cobra OEM Tech Discussion 12 June 29th, 2009 19:41
