Old January 9th, 2018, 16:18
ljobbins ljobbins is offline
Rain Leaks
So in Southern California right now we are experiencing this weird thing where water falls from the sky. Basically a few million people are freaking out and we are pretty sure the end of the world is here.
But... I personally have taken this opportunity to find all the places my Jeep leaks. I have several small weatherstripping issues that I donít really care about, however I did find water dripping in and around my fuse box and the connections behind it. With limited visibility because of everything being cramped under the dash, I can not tell if it is dripping from above or through the firewall connection. So has anybody experienced this area leaking? Iím sure I can just silicone around the firewall connection and slather dialectic grease in the connector but if itís from higher up, where is the most likely place that would leak?
Thanks
Old January 9th, 2018, 16:24
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Re: Rain Leaks
Yeah. What is up with this water from the sky thing?
And it is freaky cold too. Like 60 degrees. Can human life even subsist at these temperatures?
Anyway, as to the leak, this might be a worthwhile read: www.naxja.org/forum/showthread.php?t=1138283
Old January 9th, 2018, 16:38
Re: Rain Leaks
Well my initial reaction was to start crying when I saw that it was still raining more than 10 minutes after it started. Then I turned to the thought of panic. Then when crying and panicking didnít stop the rain, I just accepted it unhappily. I thought part of my ridiculously overpriced cost of living in Southern California went to keeping the sun up and the cold away.
But in all seriousness the link did not work. It came up with link not found.
Old January 9th, 2018, 17:02
Anak's Avatar
Mostly Harmless
Re: Rain Leaks
Hmm...
Here is what should be the same link: http://www.naxja.org/forum/showthread.php?t=1138283
And if that doesn't work, I have bumped the thread. It is Hood Release Grommets, and indicates that several folks have experienced water leaks at the grommet onto the fuse block at the driver's feet.
And yes, this rain keeps falling. I hope this isn't the end...
Old January 10th, 2018, 14:21
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Rain Leaks
Last winter, I had a bad dash leak in the 1997 XJ, on the passenger side.
It was coming around the air intake, under the cowling. The intake is sealed with a foam gasket which had deteriorated, allowing water to enter.
It was a pain to seal, requiring cutting a hole in the cowling large enough to get into the area to seal it, using polyurethane sealant.
https://www.flickr.com/photos/lwade/...7677009594362/
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old January 10th, 2018, 14:23
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: Rain Leaks
What year and model is it? Specs?
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Yes, it leaks. HELP! zeroforhire OEM Tech Discussion 6 June 20th, 2010 08:16
Boy we need rain out here scottmcneal SoCal Chapter 6 March 3rd, 2009 09:57
Rain Leaks - Accumulated knowledge 4wheelnfun OEM Tech Discussion 9 October 28th, 2008 11:57
Leaks, leaks, leaks Professor Bobo OEM Tech Discussion 14 September 24th, 2005 11:31
