Old January 8th, 2018, 22:06
Dobbie Dobbie is offline
Check oil, and Cruise Lights on dash?
Hi guys.
here with a 93 Jeep Cherokee XJ 4.0 HO Limited. One question.
When I put the keys ON ( dont fire) lights chechk oil in dash should be light ON ? only for a seconds to do the check? Mine never light on that position, i guess that is broken.
Other question, when i drive with cruise control ON, should be light ON the indicator on the dash? behind to the check oil?, Mine never light
thanks
Old January 8th, 2018, 23:09
blu3fan's Avatar
blu3fan blu3fan is offline
Re: Check oil, and Cruise Lights on dash?
I do not believe there is a oil level sensor lol.
unless its in the distributor. but I doubt it.
my 92 does not have it. and I have almost every option from the factory.
unless someone corrects me
Old January 8th, 2018, 23:24
mine is from germany
perhaps others options
on the right side we have the digital clock, under the clock, we have a green light that is the position light, another red that is warning lights, under this two, we have, check oil on red, and cruise on green.
DIGITAL CLOCK
NONE / NONE
NONE / NONE
NONE / NONE
POSITION / WARNINGS
CHECK OIL/ CRUISE
Old January 8th, 2018, 23:34
DIGITAL CLOCK
NONE / NONE
NONE / NONE
NONE / NONE
POSITION / WARNINGS
CHECK OIL/ CRUISE
Old January 10th, 2018, 14:20
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
That sounds like the "System Sentry" thing. That was a fairly rare option on very early XJs here in the states, pre-4.0 from what I found around here (see below).
I'd have to guess that someone got that panel out of another truck and stuck it in there (maybe for the clock - does the clock work) before you got your hands on the truck, unless it's documented in your owner's manual.
Did a fast search, found the following threads. The first seems to have info on what the system does, the second has a pic of the readout panel:
http://www.naxja.org/forum/showthrea...=system+sentry
http://www.naxja.org/forum/showthread.php?t=82155
Does the thing you're talking about look like the pic in the second thread?
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old January 11th, 2018, 21:53
Hi again.
This panel is original from factory,none from another truck. Then i am sad because haven,t the user,s manual, and its difficult to obtain. I will post any pic this week end, The clock works perfectly, and repeat my truck is 93 Jeep Cherokee XJ 4.0 HO Limited.
yesterday i was watching in the engine to find for two oil pressure sensors, one for the gauge in the dash, and another for the red light in the right panel, but only found one with only one wire betwen oil filter to the gauge press oil. No found the other for the red light, then i can think that perhaps this panel had options for other models?????CRUISE LIGHT and CHECK OIL ?
My truck have Cruise Control, but the green light on that panel dont light too.
Thanks
Old January 11th, 2018, 22:01
blu3fan's Avatar
Originally Posted by Dobbie View Post
Hi again.
Thanks
Could be Chrysler re-using parts from other vehicles would be my best bet.
the cruise light I believe can light up when working correctly.
but then again my cruise has never worked and im still trying to fix that.
Old January 11th, 2018, 22:05
my cruise works perfectly, i drive to 80 km/h , and then prees cruise buttom and the rig goes even to 80km/h 50 milles/h but the light dont light
Old January 13th, 2018, 00:00
Alaskan89XJ's Avatar
Alaskan89XJ Alaskan89XJ is offline
You might find the publication that you are looking for by 'clicking' on the following link;
https://www.ebay.com/sch/i.html?_odk...ual&_saca t=0
1989 Base RENIX XJ, 4.0,BA10/5,NP231,(200k+), no A/C, OME: 2" HD; coils, leafs, Nitro Sport shocks, T-Case spacer. KevinsOffRoad; steering box brace, HardKor Track Bar, stabilizer. JKS sway bar discos, (tossed out rear sway). Warn M8000 in ARB Kangaroo Bumper. OEM 15" steel wheels; 30X9.50 Dynapro muds, OEM 15" alloy wheels; 27" Blizzacks. Recycled oem seats. CIBIE/OSRAM head lights w/protective rock mesh guards. Replacement windshield, Rain-X wipers.
Old January 13th, 2018, 00:05
Thanks, but i think that is so expensive
Old January 13th, 2018, 00:09
blu3fan's Avatar
I have said book.
I can go look. its in my glovebox.
Old January 13th, 2018, 04:42
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
I donít think our 92 has light to indicate the cruise control is on.
Far as the lights on the clock, as was mentioned earlier there is a 1984-86 options with a bunch of lights in a early computer monitor system but that was very different to what youíre describing.
If you have a full gauge set up with oil pressure you shouldnít have a oil light to come on when first turn the ignition on.
The last clocks Jeep made before the redesign in 1997, so 1994-96 did have places for a bulb to go about where you are describing, but Iíve never seen one in the USA that had bulbs there that did anything. It does show jeep was thinking about using that space for something.
I also know the European Cherokees some times got slightly different clocks and dash components. My guess is your Cherokee has something unique to this market and probably a early maintenance reminder computer like some of the 1990s Grand Cherokees got. But Iím just guessing
Hereís a link for what the XJ/Cherokee clock options looked like through the years
http://gojeep.willyshotrod.com/HowtoDashClock.htm
Old January 13th, 2018, 04:46
Thanks, mine is.like 91 modelo just the same
high idle caused my dash lights/tail lights to go out?? wgregt OEM Tech Discussion 55 December 16th, 2012 18:16
No marker lights, no brake lights, no dash lights twodoorXJ OEM Tech Discussion 5 December 16th, 2012 08:35
'89 Comanche - front parking lights/dash lights not working YELLAHEEP OEM Tech Discussion 5 December 4th, 2008 15:56
dash lights, cruise control, and clock won't work... .hendrix. OEM Tech Discussion 4 December 29th, 2007 22:52
Dash Light Check, please tell me what lights up on your.. Huerito OEM Tech Discussion 4 January 10th, 2006 09:07
