Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old January 8th, 2018, 10:57
HttpWayne HttpWayne is offline
Engine Rebuilt
2000 Automatic, 4.6 Stroker with Sprintex Supercharger (has sat out back for over a year, FYI)
I have just rebuilt and engine and I am currently having a loss of power. It sounded okay when it first started up, but the longer it's been on the more it seems to be degrading. When I accelerate it's very laggy and doesn't have much power, but it does eventually rev up to around 5K.
I am also having some intermittent backfires that keep increasing the longer the vehicle is on and it's getting harder to start. I am re-using a (well inspected and perfectly okay) MOPAR camshaft with the same EngineTech lifters it used previously. It overheated and had a bent push rod because of a stuck valve last year. I inspected the lifters and watched many videos on the process and sent the pictures to the machinist. He didn't see anything wrong with them and I couldn't find anything.
The machinist that worked on the head for me is very reputable and has been machining and building engines for about 40 years at his shop.
I did a compression test on all of the cylinders and got the following (cold engine, never started, oil was primed a few days before - but I had been trying to crank it many times so a little priming was done in the mean time):
C1 - 140
C2 - 135
C3- 150
C4 - 90
C5 - 120
C6 - 135
I went back a retested and C3 was down to 125 and C4 I tested more than the rest. It always stayed at 90.
I had all spark plugs removed from all cylinders with this test.
My thinking is that I am going to retest, but this time try a spark plug on either side of the testing cylinder, then both cylinders to make sure there isn't a leak there. I suspect a cylinder to cylinder leak which is why I want to do this. I also noted a little bit of tiny oily-esque bubbles in the water (my coolant system is filled with nothing but distilled water ATM). When the vehicle is running there are no bubbles coming through the radiator cap and I don't have any air that I can burp out of the system so it doesn't seem like there's a leak there. Some oil did get inside the water jackets while I was oiling up the cylinder portions before I put the head bolts in so I suspect that is what that is. The oil doesn't look milky either.
I used 2 Victor Reinz MLS headgaskets I wanted to cut costs and was willing to deal with taking the head off if it didn't work. I investigated and although everyone naysayed it I could only find two people that actually did it and they didn't have any problems with it. Both guys were running turbos on cast iron blocks, one of them using over 20PSI and he had used that setup successfully for the past 3 years.
I don't have the dowel pins to line up and keep the head gasket in place so I used a layer of copper coat to keep them stuck together and to the head while I assembled.
The reason I used two HG's is because I had this engine custom built with a lot of compression and forged pistons that used 29CC's of dish. After Dean finished working on the head he said it would have more compression because he made the seats sit like they were supposed to. Previously the seats were in varying heights from one cylinder to the next and he didn't approve.
I am thinking that if I pull the head I will certainly inspect the lifters and cam, but if they still look fine I'm going to leave them. It seems like when you buy parts made in the US they actually last and can take a licking.
I want to know if anyone has any other recommendations on things I may be overlooking.
In regards to the super charger I see the diaphragm closing so I know boost is taking place. I just need to pull the injector to make sure the Split Second unit is reading it and opening the injector. I checked the tune to make sure it was still there from when it last ran.
Also, the exhaust setup was removed and is currently wide open, I could see the fuel injectors running at 35% fuel trim so I disconnected them for the time being until I get to the exhaust shop to finish piping it up for me. I've ran without O2's before in the past and it just runs at 10 AFR without any issues, other than decreased MPG.
My to-do list:
1. Check Sprintex injector operation
2. Compression test with alternating spark plugs in neighbor cylinder (looking for increased pressure in tested cylinder)
3. After Test 2 if I don't see any differences I'm going to purchase a leakdown tester.
Old January 8th, 2018, 12:26
RCP Phx RCP Phx is offline
Re: Engine Rebuilt
What was your deck height and cyl head chamber cc's? That #4 cyl doesn't look promising. Who's pistons are they? What valves did you use?
Old January 8th, 2018, 13:05
Re: Engine Rebuilt
The block was decked to 0. The deck height with those gaskets should be around .082"~, which is pretty close to the OEM total height given the blocked deck and the OEM gasket is .051".
The pistons are Wiseco and the valves are Manley, stainless steel. 1.5" exhaust and 1.94" intake.
Cylinder head chambers are 60cc.
Old January 8th, 2018, 13:40
Re: Engine Rebuilt
I've decided I'm just going to use one head gasket. The numbers are still safe for one, I just need to always use 90 octane or more.
I ordered the last VR off RockAuto and a set of push rods slightly longer to compensate for the difference. I got 9.677" Sealed Powers off of Summit Racing on the way.
Here's my engine math in case anyone is curious. It's as compressed as I think it can be to safely run 6-8lbs pounds of boost. I had to get a 49mm pulley from Sprintex to be able to make boost on a stroker along with a 68mm F&B throttle body.
4.6 - 2017/2018 - Dean's Golen Stroker
.000 Deck
.042 Victor Reinz MLS Gasket
0.042 Quench
Wiseco Forged Pistons, 29CC's Dish
MOPAR Cam: P4529228AC
IVCA: 48 Degrees
Intake: 240 Degrees
Lobe Sep: 108 Degrees
Naturally Aspirated Compressions
Static: 8.83 (OEM = 8.7)
Dynamic: 7.88 (OEM = 7.47)
Boosted Effective Compressions, @ 6PSI
Static: 12.43 (OEM = 12.25)
Dynamic: 11.10 (OEM = 10.52)
Calculations performed using the following links:
https://www.jeepstrokers.com/forum/calculator/
https://www.rbracing-rsr.com/compression.htm
Old January 8th, 2018, 17:10
Re: Engine Rebuilt
I just realized I ordered PR's .030 over instead of .030 under. It should read 9.621 above but I don't have the hacks to edit my post (in case anyone else uses this for reference in the future years from now)
Old January 9th, 2018, 02:01
Re: Engine Rebuilt
I would not try and do "math" with pushrod lengths. The only proper way is to measure!
Old January 9th, 2018, 06:35
Re: Engine Rebuilt
Yeah but.. I'm a really good guesser
Old January 9th, 2018, 09:53
Re: Engine Rebuilt
What rockers are you using? I would also recommend getting some ARP head bolts to hold this thing together.
Old January 9th, 2018, 17:06
Re: Engine Rebuilt
I am using... whatever Golen used. I just got the valve cover off and I didn't like what I saw. The first 3 cylinders' rocker arms were all loose and the the last 3 were semi loose.
One lifter sprung apart. I believe it is the exact same one that the valve got stuck on when it overheated. I guess 1 overheat is the limit for lifters.
I'm taking the head, the rockers, push rods and all the lifters to the machine man tomorrow because he wants to inspect and see.
What I didn't like when I was tightening down the rockers using the spinning the push rod method by hand was that most of the rocker feet were sitting off of the pedestals they bolted to 1/8th to 1/4 of an inch. That didn't seem right. The Haynes manual I have says to torque them but then how do you set preload on the lifters? It got too tight too soon for that to seem right. I pre-pumped the lifters before I put them in. That's exactly what I did with the first engine I built though and it wasn't an issue. Do I need to get shims for the rockers?
Old January 9th, 2018, 20:01
trippled trippled is offline
Re: Engine Rebuilt
As far as I know, the factory rockers have to by torqued down. It's just a bolt so if it's not tight it will come loose. It's not like a small block Chevy that uses the method you describe. The pushrods need to compress the lifter some, that's their purpose.
Old January 10th, 2018, 04:35
Re: Engine Rebuilt
Should they compress the lifter a quarter of an inch?
Old January 10th, 2018, 04:38
Re: Engine Rebuilt
Scratch that, they're not compressing the lifters, they're opening the valves. I sense I need shorter push rods, shorter than the ones I just ordered.
Old January 10th, 2018, 07:09
Re: Engine Rebuilt
Regarding camshafts, I have the dowel pin setup. The other is a keyway in the nose like a crank. I could get a timing set for $24 from RockAuto and the keyway setup (That's the actual 2000 and later design which my vehicle is, but I bought a dowel setup years back).
Does anyone know of any differences that should be considered? I am going with the OEM supplier, EngineTech.
Or does anyone know of any other reputable cam provisioners that have their cams made in the US and not bought overseas and just reground? I'm trying to avoid cost cutting cheap metallurgy used in the materials which I am certain EngineTech and Mopar avoid.
Old January 10th, 2018, 07:57
Re: Engine Rebuilt
You have to get the proper lifter pre-load so that's where measuring starts. When I did the stroker build on my 2000 I switched over to the early cam for better/more cam options plus the ability to run a better timing chain.
Old January 10th, 2018, 09:18
Re: Engine Rebuilt
I decided on Comp Cams more stock'ish grind with a little more intake valve opening time. I spent the extra $150 to have it nitrided for 36 hours as well.
I also went with their higher energy lifters which certainly sound like an improvement. It's going to be as resilient as is humanly possibly for a stroker to be.
Rate This Thread:
Rebuilt Engine vs. Rebuilt Engine tn_outside2003 OEM Tech Discussion 15 September 27th, 2013 17:58
Has my engine been Rebuilt? stephenspann27 OEM Tech Discussion 4 October 16th, 2008 11:58
Anyone here rebuilt an engine BIgDaddyChia Red River Chapter 8 March 1st, 2008 05:11
rebuilt engine outlander OEM Tech Discussion 7 November 10th, 2005 11:37
Is my engine rebuilt tnfan77 OEM Tech Discussion 6 August 27th, 2003 08:39
