Old January 7th, 2018, 07:39
HttpWayne HttpWayne is offline
How to Properly Torque the Cam Sprocket
I have a 2000 XJ with the auto.
How do I keep the crank and cam sprockets in place to torque the cam timing gear to spec? I have an auto and even in 1st gear the crank just spins freely. When you're putting those sprockets on you don't have a harmonic balancer to use to lock it down to the sway bar with a coat hanger. How does anyone ever torque these things down?
I've always just hit it with an impact gun but I want to try to do it right this go around. I impact gun'ed the crank bolt as well since I had the engine on the stand at the time but I found it wasn't hard to get that bolt to come off, so proper torque needs applied.
Old January 7th, 2018, 07:53
Dragonlich1961 Dragonlich1961 is offline
Re: How to Properly Torque the Cam Sprocket
You can buy a socket that is desinged to slip onto the end of a crankshaft like a harmonic balancer does. second way would be to wedge something between the flexplate teeth and the bell housing to stop the flexplate from rotating.
Old January 7th, 2018, 07:57
Sounds dangerous. I already am missing half a tooth back there.
Wait... I should be able to put the balancer on the end of the snout and coat hanger that to the sway bar. That just might work. I guess waiting to reassemble the timing sprockets always needs to wait until the engine is reinstalled.
Old January 7th, 2018, 08:07
recomend two people for the flexplate trick, they acutually make a tool desigend for holding the flexplate. i would recomend either installing the balancher and doing it that way or buying a crankshaft socket and using it.
something like this, allthough is is listed for a chevy. ( https://www.amazon.com/Proform-66901...ft+socket+jeep )
This is the flexplate tool. (https://www.amazon.com/Lisle-23800-F...lywheel+turner)
Old January 7th, 2018, 09:59
Thanks for the informations. Can that flywheel turner be used through the flywheel cover plate or does the transmission need removed?
Old January 7th, 2018, 12:56
It would need removed. That's why you would use a screwdriver in the teeth through the starter hole.
Old January 7th, 2018, 14:30
RCP Phx RCP Phx is offline
This is my 2k. Use something as a "spanner" to hold the cam gear and "offset" torque the bolts(torque against the rotation, leverage is your friend).
There are several "webs" that you could grab on to with a ratchet hanlde.
Old January 8th, 2018, 07:10
What timing set is that? I have a cloyles. That crank sprocket has a lot of options for you to choose from.
I ended up using the harmonic balancer with a coat hanger to the sway bar.
One day I'm going to have to pull the transmission and torque those engine to flywheel bolts properly. I just hit it with an impact gun several times like I did last time.
Old January 10th, 2018, 08:00
It's a Rollmaster TC set with a 7 way adj crank gear.
H1 sprocket and Chain in NP242J Owenclemmons Modified Tech Discussion 1 March 31st, 2016 04:31
How to properly install a Torque Converter/Pump Ring Bushing? QuillsXJ OEM Tech Discussion 8 June 21st, 2013 15:06
CAM SHAFT SPROCKET Boatwrench OEM Tech Discussion 1 March 21st, 2011 16:10
Cam Sprocket Mod gradon Jeep Picture Showcase 6 February 15th, 2011 18:41
How can I tell if my Torque Convertor is properly seated. twoplanker OEM Tech Discussion 18 May 21st, 2010 23:37
