8.25 axle question
blu3fan
Arizona
I wanted to check before I go ahead and do it.
My rear 8.25 is bent .75 of a degree on the passenger side since about 10 years ago.
I finally bought a junkyard 8.25 and all 110 lb's of me dragged it into my car and home. LOL that was fun.
the car it came out of had no engine or transmission and i did not check the vin to find out what engine was in it. it was a 96-00 xj tho.
I have a 92 laredo 4.0 with the aw4
Do I have to worry about the other 8.25 having different gears ?
and how is the easiest way to figure it out.
I know there is a 29 and 27 spline. but that does not matter for this I believe.
been wrenching on cars for years. but axles I am kinda new to axles and swapping them.
thanks for any info.
Best thing as with any jy axle, pull the cover and check the ring gear numbers. There should be something like 41 10 which is a 4.10 gear ratio, or countthe teeth to figure it out.
The most reliable way is to pull the cover and look at the numbers stamped into the ring gear.
This advice applies to just about any repairs/replacements when the necessary technical info is actually critical info for the success of the project. There is no way to determine what sort of parts swapping has been done in the vehicles past ownership and maintenance. Build sheets that detail the installed components by decoding the VIN are not typically available for early 1990's and older Cherokees, unless you find the actual build sheet inside your Cherokee. Early Chrysler build sheets often contain nonsensical "options" because the option codes were recycled during later model years.
blu3fan, simply open the diff cover on both axles and read what the gears are stamped. You should also perform an inspection of the condition of the gears and shims before you begin the swap. What if you bought an axle that is damaged and you waste all that time and effort for nothing ?
This isn't extremely accurate but it will give you a decent guess
Prop the axle up so you can rotate both tires or hubs if no tires
Mark the housing so you can count # of rotations of the Yoke
Spin tire 1 complete rotation, counting rotation of spindle -- 1 full turn of tire and 3 plus a little is 3.07 -- 1 tire rotation and 3 and 3/4 rotation of yoke is 3.73 -- 1 rotation of tire and 4 and a little is 4.10
Not very accurate but will get you in the ballpark -- But you bought an unknown junkyard rear -- pull cover and check -- you really should no matter what -- could be filled with mud
You want to open up and inspect the internals of any used axle you buy anyways (as well as change the fluid), so open it up and count the gears or look for the stamp.
My main reason for asking is so that when I go to swap it.
I am not out of a car for a day due to having to swap internals.
this is my daily.
the info about checking with jeep about my vin is a great idea
I can pull the Junkyard axle apart and compare.
thanks guys
Inspect the axle you bought and determine the gear ratio and condition of the internal parts. If it all checks out, put the cover back on and fill it with gear oil. On the work day, pull the diff cover on the existing differential, and determine the gear ratio. If the ratios match, proceed with the swap, if the ratios do not match, put the cover back on and re-fill it with gear oil. Unless you have the necessary specialized tools and technical knowledge you will not be swapping any internal parts from one axle to the other.
I suggest you inspect and service the brakes before the swap, and that you buy a set of new u-bolts also.
I read you telling me not to swap the two if they are different.
but I will....
I built my 4.6 stroker myself.
Nothing is impossible. the internet is vast with information..
It certainly can be done, but be aware that you will need a bunch of somewhat specialized tools. Among other challenges, the 8.25 has a pair of large nuts which are used to set the side preload on the bearings. These nuts are accessed through the sides of the axle housing. IOW, a long tool is needed in order to reach in through the brake flange end of the equation.
It would be in your best interest to first figure out what your own axle ratio is (probably 3.55) and then also figure out the ratio and general condition inside the second axle. It the donor vehicle was a 4.0 with a stick shift it should have 3.07 gears (Just an example of a likely difference). And yes, the internal picture could also be a train wreck.
You are getting good answers to your questions (and they are some of the right questions to be asking).
Do I have to worry about the other 8.25 having different gears ?--Yes
and how is the easiest way to figure it out.--See earlier posts describing different methods.
I know there is a 29 and 27 spline. but that does not matter for this I believe.--Not if you swap complete axles, but it will start to matter if you try to swap some components, but not others. If you were to swap all internals things should go fine, but if one axle shaft is bent from the damage to your old housing you will not be able to not swap that shaft thinking you will use one shaft from the old and one from the new. (I hope that makes sense...)
Makes sense.
Worst case scenario I can get those 4.11 gears with the lunchbox locker ive been looking at :p
I mean if I havveee to spend the money :)
Makes sense.
Worst case scenario I can get those 4.10 gears with the lunchbox locker ive been looking at :p
Yup, XJs are like a box 'o chocolates! ;)
Makes sense.
Be aware that a lunch box locker is where many people run up against an annoying reality with these axles. You cannot use a lunch box to convert a 27 spline carrier to 29 spline. You also cannot put a lunch box in a limited slip carrier.
Call that one more reason to figure out what you really have before you spend any money going a particular direction.
100%
I did a few hours of research into the options available.
it appears its a lot more inclusive than I originally thought.
read that about the lunchbox.
Tomorrow. I am opening this axle up.
ill get back with pics and such.
so both are 3.55
the new axle looks brand new inside. teeth show no wear.
understandable... the xj I pulled this axle from had 45k on the clock.
to confirm. am I good to just swap the axles now ?
Nice idea, but you're doing it wrong.
You'll get a 1:1 ratio that way- you're spinning the spiders.
Leave a tire on the ground. Count the revs of the pinion.
so both are 3.55
If the ratios are the same as your old one, then you can just swap the whole axle over. I always recommend new U-bolt anytime you are removing old, original ones but that's your call.
so both are 3.55
Sure sounds like it to me. I think that is about as good as it gets.
I will reiterate the suggestion to get new U-bolts. When I removed my first axle one of the U-bolts broke before the nut would start to move. Also note that new U-bolts will probably not come in the exact length you need. Too short won't work at all, so you will probably end up with something that is too long. Plan to cut off the excess. Also note that you will want to re-torque the U-bolts after the first hundred miles.
Another potentially useful tidbit: One way or another you are going to be disconnecting the e-brake cables. I have found that the simplest way to get all three tabs on the cable housing compressed at one time is to use a short (like 1") piece of 1/2" copper tubing cut with a roll cutter. The ID of the copper tubing is a bit too big, and the ID as cut with the roll cutter will probably be too small, but with some judicious deburring you should be able to get it just right. That sure beats trying to work your way around the perimeter trying to get one tab at a time through the hole in the backing plate or bracket.
Oh, and one other maybe useful tip: An old lawnmower makes a reasonable axle dolly: http://www.naxja.org/forum/showthread.php?t=1143659
