Old December 31st, 2012, 16:25
Crist Clapper Crist Clapper is offline
NAXJA Forum Supporter
Tail-lamps
Now seems like a good opportunity to get educated... Below is the parts list for my XJ... I interpret all the tail-lamp choices will fit. The NOS I have is item #14. Thoughts?
1971 Ford Mach-1 ~ Restoration in progress
1987 Jeep XJ-Limited ~ Restoration just started
1990 Jeep Grand Wagoneer ~ Restoration just completed!
2007 Jeep Liberty ~ 2007 Jeep Commander ~ 2008 Jeep SRT
Old December 31st, 2012, 16:44
NotMatt's Avatar
NotMatt NotMatt is offline
Re: BUILD: My 1987 "Wagoneer" XJ Limited
Number 14 says "MJ" under body, at the bottom of that page it says "MJ = Comanche Pickup". You have a comanche tail light housing. It doesn't fit your XJ body... try it, it appears you have the rig all apart already anyway, but you'll find that you can't match the screw holes up, and the body countour is different where they bolt up anyway. Sell it here or on Comanche Club, it's a NOS passenger side comanche tail light housing with chrome trim, they are hard to find and someone will pay you more money for it than it will cost you to find another NOS wagoneer tail light housing most likely.
You need a number 1 on that diagram, 8350 4116 "Wagoneer, Red"
Old December 31st, 2012, 16:50
NotMatt's Avatar
What I'm curious about is what the difference is between the standard XJ tail lamps and the ones that say "ECE" behind them... from a quick google search it appears ECE stands for Economic Commission of Europe, so I assume they are european models... maybe with different reflector or color configuration....
Old December 31st, 2012, 17:54
There is a European version which may also be an option... I do wish it had chrome-trim:
Old January 14th, 2013, 16:47
The XJ is still at the paint-shop... And I'm still shopping!
An unbelievable find of a NOS "Overlay"! It's the chrome piece above the rear license-plate. He also had the other Cherokee chrome tail-lamp... Although I can't use them... At least I'll have a NOS pair!
Old January 15th, 2013, 07:35
NotMatt's Avatar
Again, that is a Comanche tail lamp lense, NOT a Cherokee or Wagoneer.
Old January 15th, 2013, 08:50
Maybe you missed my "although I can't use them"... Then since I have an XJ... I still get the "other" models confused!
Old January 15th, 2013, 09:01
An unbelievable find of a NOS "Overlay"! It's the chrome piece above the rear license-plate. He also had the other Comanche chrome tail-lamp... Although I can't use them... At least I'll have a NOS pair!
Old January 15th, 2013, 09:55
heyhar's Avatar
heyhar heyhar is offline
From what I've read, the Euro models have a fourth circuit and bulb socket for the tail lights for 'fog lights'. Even the stock XJ US market tail light housings have the fourth hole, but no bulb socket. I believe it lights up if you turn on your front fogs. They are as bright as the stop lights. One car that comes to mind is the earlier Lexus IS series. There's two extra tail lights on the trunk lid, that when illuminated, are brighter than the running lights, about as bright as stop lights. I guess they're legal here, as a few other Asian cars seem to be sporting them, too. Lately it's been warm, and foggy, and it'd be nice if more vehicles had them.
Old January 15th, 2013, 11:56
I have seen similar while in Europe. Below-left is my old OEM... Below-right is a new Import. I won't know about the wiring until I get my XJ back. So for now... FYI:
Old January 15th, 2013, 12:59
heyhar's Avatar
I've seen the chrome overlay license plate 'eyebrow' in the junkyard a few times, always on older Waggys, and they said Wagoneer, not Jeep. That is a cool find! Toward the end of the run, the only time I saw the chrome strip would be on a Limited, and then not always. It's amusing to see the way XJs were optioned through the years. My son's '95 former police Jeep was a fully loaded Sport, power doors and all, but without a center console. My '96 Country has crank windows !
In your picture, on the older one on the left, my guess is that the Euro foglight would be the second hole from the top. It would be interesting to find out if the wiring for the fogs is in fact in the harness, just without a bulb socket on it. My '96, which didn't come with factory fogs on the front bumper had the switch wires at the place where the switch would have been. I swapped for a bezel with the switch, and it plugged right in. I added the front header harness and relays from a donor with factory fogs, and now I have 'em too.
Old January 15th, 2013, 14:19
sandsgg sandsgg is offline
I could use those mj taillights
Old January 15th, 2013, 15:55
Now I'm even more excited about checking mine out!
Old January 15th, 2013, 16:14
Eight minutes on eBay NOS:
Old January 16th, 2013, 15:20
Unlikely I'll need the set... Someday I'll post them on eBay.
XJ: 1987 Wagoneer Limited Or? Windshield trim? Crist Clapper Wanted: Private Party Only 5 November 13th, 2012 16:41
1987 Wagoneer XJ Limited - Trim color? Crist Clapper OEM Tech Discussion 5 July 15th, 2012 16:11
Parting out: 1987 Wagoneer Limited YELLAHEEP For Sale: Private Party Only. XJ ITEMS ONLY 8 June 25th, 2007 22:55
Parting out 1990 XJ "Wagoneer" Limited XJ&CHZ4ME For Sale: Private Party Only. XJ ITEMS ONLY 14 December 16th, 2006 22:19
1987 XJ Wagoneer 6.5" Lift on 35`s + Extras Fairmonco For Sale: Private Party Only. XJ ITEMS ONLY 12 September 15th, 2006 15:37
