Old January 8th, 2018, 20:04
blu3fan's Avatar
blu3fan blu3fan is offline
Re: 8.25 axle question
Originally Posted by Anak View Post
Be aware that a lunch box locker is where many people run up against an annoying reality with these axles. You cannot use a lunch box to convert a 27 spline carrier to 29 spline. You also cannot put a lunch box in a limited slip carrier.
Call that one more reason to figure out what you really have before you spend any money going a particular direction.
100%
I did a few hours of research into the options available.
it appears its a lot more inclusive than I originally thought.
read that about the lunchbox.
Tomorrow. I am opening this axle up.
ill get back with pics and such.
Old January 9th, 2018, 12:55
blu3fan's Avatar
so both are 3.55
the new axle looks brand new inside. teeth show no wear.
understandable... the xj I pulled this axle from had 45k on the clock.
to confirm. am I good to just swap the axles now ?
Old January 9th, 2018, 13:06
burntkat burntkat is offline
NAXJA Member #1145
Originally Posted by Heavyopp View Post
This isn't extremely accurate but it will give you a decent guess
Prop the axle up so you can rotate both tires or hubs if no tires
Mark the housing so you can count # of rotations of the Yoke
Spin tire 1 complete rotation, counting rotation of spindle -- 1 full turn of tire and 3 plus a little is 3.07 -- 1 tire rotation and 3 and 3/4 rotation of yoke is 3.73 -- 1 rotation of tire and 4 and a little is 4.10
Not very accurate but will get you in the ballpark -- But you bought an unknown junkyard rear -- pull cover and check -- you really should no matter what -- could be filled with mud
Nice idea, but you're doing it wrong.
You'll get a 1:1 ratio that way- you're spinning the spiders.
Leave a tire on the ground. Count the revs of the pinion.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old January 9th, 2018, 13:23
xj_mike's Avatar
xj_mike xj_mike is offline
Originally Posted by blu3fan View Post
so both are 3.55
If the ratios are the same as your old one, then you can just swap the whole axle over. I always recommend new U-bolt anytime you are removing old, original ones but that's your call.
XJ_Mike
1999 Cherokee Sport 4x4, Still stock...
2000 Cherokee Classic 4x4, Lots of stuff. SOLD but should have kept...
Old January 9th, 2018, 15:27
Anak's Avatar
Anak Anak is online now
Mostly Harmless
so both are 3.55
Sure sounds like it to me. I think that is about as good as it gets.
I will reiterate the suggestion to get new U-bolts. When I removed my first axle one of the U-bolts broke before the nut would start to move. Also note that new U-bolts will probably not come in the exact length you need. Too short won't work at all, so you will probably end up with something that is too long. Plan to cut off the excess. Also note that you will want to re-torque the U-bolts after the first hundred miles.
Another potentially useful tidbit: One way or another you are going to be disconnecting the e-brake cables. I have found that the simplest way to get all three tabs on the cable housing compressed at one time is to use a short (like 1") piece of 1/2" copper tubing cut with a roll cutter. The ID of the copper tubing is a bit too big, and the ID as cut with the roll cutter will probably be too small, but with some judicious deburring you should be able to get it just right. That sure beats trying to work your way around the perimeter trying to get one tab at a time through the hole in the backing plate or bracket.
Oh, and one other maybe useful tip: An old lawnmower makes a reasonable axle dolly: http://www.naxja.org/forum/showthread.php?t=1143659
Old January 9th, 2018, 20:14
blu3fan's Avatar
Going to use a jack. with a ratchet strap to hold it.
as for the E brake cables.
Im not using the junkyard e brake cables attached. mainly cos I damaged them. after i got annoyed removing them. I tried to cut through them.
didnt go well
I am going to remove the e-brake lines inside the brake shoes.
then attach mine to the new axle.
I bought rough countries extended brake lines.
they are nice quality.
My main quandary right now is that I want that red ARB cover
but its $200
:P
Old January 9th, 2018, 23:31
JeepNoob JeepNoob is offline
Jeezless H. Chrysler of Highland Park, Michigan on a donkey... leave it to the intertoobz to complicate things...
I worked at a salvage yard for a bit that dealt with Jeeps and Jeeps only. As others have pointed out, the best way to figure out your gear ratio is by checking your ring gear. There will be two numbers, one will be the number of pinion teeth, the other will be the number of ring gear teeth. Divide them to figure out your gear ratio. Automatic tranny 4.0 XJ's came from the factory 3.54/3.55 gears. Really, it's a toss-up because if you use the method I described, the actual number comes out to 3.545-something. Some folks round that up, some down.
Just because a Jeep SHOULD have X-part or gear ratio in it per the VIN doesn't mean it always does. I took apart one XJ that had 3.07 gears in the back and 3.73's in the front. Probably explains why the gears up front were shattered...
As far as the E-brake cable goes... I can't exactly remember how we got around those. I think we just unbolted them at the tensioner assembly where the brake cable from the handle meets the "wing." Otherwise, you'r looking at taking the rear drums apart to detach the brake cable there.
Old January 10th, 2018, 02:38
techno1154's Avatar
techno1154 techno1154 is offline
A 1/2" box/ring spanner/wrench get the job done.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Another axle question frozen chosen Modified Tech Discussion 10 January 26th, 2009 11:31
Axle question 99xjstl Modified Tech Discussion 2 June 27th, 2006 23:18
axle question jeeppowermj Tow Rigs and Trailers 0 February 13th, 2005 16:17
Axle Question HELP !! XJOFFROAD Modified Tech Discussion 4 October 31st, 2004 20:17
8.8 axle question,.. BILLXJ Modified Tech Discussion 2 April 27th, 2003 21:45
