Old August 12th, 2017, 20:25
EMSJEEP's Avatar
EMSJEEP EMSJEEP is offline
No Start after a year off
Ugh, so the 2001 came off the road for a while as it got retired from DD. The gas in the tank turned and I didn't start it for a year because of that.
I dropped the tank and noticed a mouse nest around the fuel pump. They started to eat the insulation, I rewrapped everything there. Poured out 10 gallons of brown gas, refilled with premium, stabilizer and MMO. Pulled the plugs, MMO in the cylinders before cranking. Now, nothing. Cranks fine, fuel level is giving wonky readings. The pressure purge in the fuel rail drains good gas, so it appears to be pushing fuel in. Plugs looked ok when I pulled them. Only hint is an intermittent P0340. Fuses look ok.
Where do I start? Thanks!
Old August 12th, 2017, 21:49
ehall's Avatar
ehall ehall is offline
Re: No Start after a year off
air, fuel, compression, spark
have you tested fuel pressure with a gauge?
have you tested spark?
my '91 beater rebuild
Old August 12th, 2017, 22:44
EMSJEEP's Avatar
Almost noting in the way of specialized tools out here in the middle of nowhere where I parked the thing. If I can't figure it out this week, I'll start getting involved next week.
I'll pull the rail tomorrow and verify spark.
Old August 13th, 2017, 07:50
ehall's Avatar
Autozone will rent/loan a fuel pressure tester for $150. Harbor Fright sells them for $20. Don't know if either of those are options for you.
Advance sells a Lisle inline spark tester for $15ish that's pretty good.
Old August 13th, 2017, 08:24
EMSJEEP's Avatar
I've got an ACE hardware, a bait shop and a ratchet set. That's about the extent of it.
Old August 13th, 2017, 08:58
EMSJEEP's Avatar
So, with the distributor rail off and a plug stuck into it, I see no spark while cranking.
Gonna go find the CPS and see what I can see.
Old August 13th, 2017, 09:14
trippled trippled is offline
You likely won't see spark testing like that since it has to fire 2 plugs at once. You have a test light I'd check for coil flash at the connector when cranking .
Old August 13th, 2017, 11:42
ehall's Avatar
Use a vacuum hose in your ear to listen to the injectors while cranking. Crank and Cam sensors (and ASD relay and the ECU) control timing for spark and injectors both, if you have one or the other then they are good.
Old August 13th, 2017, 12:37
comanche91's Avatar
comanche91 comanche91 is offline
Only hint is an intermittent P0340. Where do I start? Thanks!
Since it's been sitting so long, try unplugging the CPS connector in the engine bay, clean it up, and try it again. Maybe you'll get lucky.
Old August 13th, 2017, 14:09
EMSJEEP's Avatar
I can't find the darn thing. This is an 01 with the pre cats and there is an O2 sensor connector where the CPS is supposed to be. Internet has been less than helpful in locating so far. Found one diagram that suggests it is passenger side on the engine? Dunno.
It has a permanent CPS code now.
Old August 13th, 2017, 16:02
EMSJEEP's Avatar
So CPS plug sits below the vehicle next to one of the O2 sensor plugs rear and down from the sensor itself. Plug looked clean. Unplugged and plugged back in a few times. Code returned with each crank. Think I'm going to come back next week with a new sensor and the rest of the necessary tools.
Old August 19th, 2017, 15:31
EMSJEEP's Avatar
Replaced CPS, no change. Picked up the fuel line disconnect tool. There is no gas in the lines, no less pressure. Pulled the fuel line apart at the first connection from the pump, bone dry. The gauge isn't doing wacky stuff anymore, just flat empty after adding 10 gallons.
Guessing fuel pump? The mice chewed the insulation off the lead wires from the pump, but they are still intact. All fuses look good.
Old August 19th, 2017, 15:37
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Do you hear the pump run for a second or so when you turn the key to ON? Also, could the relay for the pump have gotten stuck/failed?
If you can work out which wire is which, try running 12V straight to the pump and see if it runs at all. If it runs, you can start working your way back along the wiring to the relay.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old August 19th, 2017, 15:49
EMSJEEP's Avatar
When you say "on" you mean the position before cranking, correct? I'll be searching for a diagram....it's 4 pins
Old August 19th, 2017, 19:50
NAXJA Member #920
Yep, last position before crank.
1984 Dodge Omni
Still no start, after a year. MountainRhino OEM Tech Discussion 12 January 31st, 2012 21:37
which year did steel hatches start? Kejtar OEM Tech Discussion 31 July 20th, 2004 15:46
non-vaccum front end, What year did they start? isaacson OEM Tech Discussion 1 June 29th, 2004 12:37
What year did they start useing the 8.25"? 88woody OEM Tech Discussion 6 April 28th, 2004 19:57
Which year did 8.25's start to have 29 splines? telemike OEM Tech Discussion 1 July 23rd, 2003 05:56
