Old August 12th, 2017, 14:15
shmicah shmicah is offline
TRE boot cut open by DS wheel
I just replaced all the TREs in my front steering. I am all stock tires/suspension/etc.
I drove it a few days, maybe 10 miles total. I was back under the car today checking on everything, and noticed a shit ton of grease all over the driver side wheel hub and rim. It had definitely burst/spewed while driving as grease was smeared in a circle all the way around the tire, and was collected into a clump @ the knuckle or brake(?)
I felt back there and sure enough the boot has a perfect split across it. It feels more like a cut then a rip, so I think it was cut via rubbing against the wheel hub (or some part of wheel) while driving.
The TRE is definitely a tight fit in there. Is this a common problem? How on earth do I fix that/why would it be rubbing like that?
EDITL: the only other thing I can think of is that when I was back under the Jeep (I was replacing draglink again), so I disconnected TRE from draglink and let it hang. I remember hearing the TRE @ the DS knuckle squirt some grease. Is it possible that when I disconnected the TRE from the drag link and let it fall, it squeezed all the grease to one side of the TRE @ knuckle and made it split open? Is that more likely?
Old August 12th, 2017, 16:32
Jeep Driver Jeep Driver is offline
Re: TRE boot cut open by DS wheel
You over filled the TRE with grease, the dust cover burst under pressure.
1-3 pumps, that's it.
Old August 12th, 2017, 21:22
lawsoncl lawsoncl is offline
I would agree. Too many folks think they need to pump until they see them leak grease.
Old August 13th, 2017, 15:31
Yeah and pumping until I saw the old grease start to seep out is what I did
That's what I read online and thats what I did., Lesson learned, oh well. Guess that will be my third trip to NAPA
V8 ZJ tie rod boot 96 XJ Sport Modified Tech Discussion 13 August 26th, 2012 17:09
Best All Around Boot GhostDakota Non-Tech / Off Topic 25 December 29th, 2011 13:05
dome lights dont come on when doors open but do when hatch is open 90Pioneer OEM Tech Discussion 8 December 7th, 2010 08:50
any problem with leaving axles open/open? moparjim1987 Modified Tech Discussion 30 October 7th, 2009 07:06
steering stabilizer boot ot no boot? bcmaxx OEM Tech Discussion 6 January 24th, 2008 17:08
