Old August 10th, 2017, 08:35
Jet noise Jet noise is offline
Idle issue
So I just bought a 97 XJ, 4.0l, auto, 242 t case. It used to be a government vehicle and has 160 on the odo. It ran fine when I bought it, ran smooth for another week or so, until now.
My issue is, the jeep will start and run, as long as I keep my foot on the gas. Take foot off pedal, and she dies. I just will not idle. I swapped the MAP sensor off my 01XJ, and that didn't help.
Looking for pointers on where to look!
Old August 10th, 2017, 09:35
comanche91's Avatar
comanche91 comanche91 is offline
Re: Idle issue
TPS or possible CPS. Did you check for fault codes?
Old August 10th, 2017, 12:49
SBpunk SBpunk is offline
Re: Idle issue
Check the kick down cable make sure its tight. Easy and free box to check off. Next look for the EXT IDLE switch should be around your fog lights/rear wiper area. Mess with that see if it helps (switch to the other position). Once that's done head down to Orielly Auto if you have one. Rent a fuel pressure testing kit. You're going to have to google what its supposed to be at. Crank it and test to make sure you have fuel pressure and return it.
Even before that check the vacuum on the MAP sensor, fuel pressure regulator, brake booster and the rest of them.
Before you buy new sensors check out strokedjeep.com and shoot him an email. He usually has throttle body sensors for dirt cheap and test them before sending them out. I'm thinking its most likely a vacuum issue.
Old August 10th, 2017, 12:52
Idle issue
I did, there were no codes.
Old August 10th, 2017, 12:53
old_man's Avatar
old_man old_man is offline
Re: Idle issue
How about scanning it with a computer first?
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Idle issue
Good info, thanks! I'll do some checking tonight 👍
Old August 10th, 2017, 13:18
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
Re: Idle issue
It sounds like you have the combination of a dying battery and a dirty throttle body. If you clean the throttle body it should fix your issue. Also you might want to get your battery checked.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231 8.25/D30 ARB's 4.56's 33's deavers and a few other things.
Click here to join the red team
Old August 10th, 2017, 13:39
RCP Phx RCP Phx is offline
Re: Idle issue
You also need to check the IAC.
Old August 12th, 2017, 16:01
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: Idle issue
Any other issues other than it dies at idle?
Could be any of a number of things. Get a volt meter and test the TPS idle position voltage.
May just need a tune up, new air filter (is it soaked in oil?), spark plugs (are they fouled, gap too wide from wear), cap and rotor (too worn and eroded?).
IAC may be fouled and sticking. Idle Air Control. Pull a vacuum hose loose on the intake manifold (use the one in the rear that goes across the top of the engine to carbon canister on the passenger side) and if see it idles with out dying? Ill bet it runs when you do this!!!! If it does, you need to focus on why it is starving for air at idle.
Air filter, IAC, TPS are top selections.
CPS can be tested sort of with an ohm meter, but it is no conclusive.
What???? Kick down cable for an idle issue? WTF is an EXT IDLE switch?
Are you talking about XJ jeeps or what?
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old August 12th, 2017, 16:03
Ecomike's Avatar
NAXJA# 2091
Re: Idle issue
If it starts and cranks, I would not suspect the battery for an "it runs if I give it gas, but will not idle..." Also it is OBD-II with no codes thrown.
Old August 19th, 2017, 11:12
Idle issue
Thanks for all the help, guys. I let it sit for a while before I had a minute to mess with it. Today I pulled the throttle body off and gave it a good cleaning. I didn't think this would fix my issue because it wasn't overly nasty. Anyway I cleaned it all up and put a new gasket down. Hooked it all back up and cranked her up. She was rough at first but smoothed right out and runs like a champ now.
Odd idle issue W1zardofozz OEM Tech Discussion 1 February 15th, 2016 09:42
idle issue frankrizzo OEM Tech Discussion 1 April 7th, 2012 19:49
Strange idle/brake issue/ voltage drop issue stockli OEM Tech Discussion 0 May 15th, 2011 18:02
Idle issue Cowboydoc OEM Tech Discussion 0 August 7th, 2007 08:18
Idle Issue jeepsrock OEM Tech Discussion 15 March 20th, 2006 18:27
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
