Old August 6th, 2017, 21:05
Sub Zero Sub Zero is offline
Idler pulley question
My idler pulley grenaded on my way into work last night. I got a gates replacement pulley from O'Reilly, but the dust cover for the front of the pulley will not fit in the inside diameter of the new pulley. The pulley did come with a new "spacer" but I'm not sure if it should go on the front or the back of the pulley as I've seen videos of replacement pulleys with a rear dust cover instead of the front. The xj is a 94 with the 4.0. Any ideas?
Old August 7th, 2017, 00:57
Re: Idler pulley question
Nevermind, got it all figured out. Thanks
Old August 7th, 2017, 10:04
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Glad we could help!
For posterity; what was your answer
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
SoCal Chapter VP
Old August 7th, 2017, 21:37
It goes on the front side like the factory setup. I checked the depth on the factory spacer and the gates spacer and they both sat the same depth inside the bearing, just and updated part to fit the smaller inside diameter of the new pulley
Old August 7th, 2017, 22:42
Anak's Avatar
Anak Anak is offline
Mostly Harmless
I can't remember which brands were involved, but I replaced my idler pulley a couple of years ago, and I didn't like the first version I got (perhaps from Napa), so I went questing and found another store with a version much more like the OE pulley (perhaps vatozone?).
IIRC the first one that I rejected had the bolt recessed in a well with steep sides such that you had to use a socket to access the bolt, and the OE design, and what I sought and found, had the bolt head recessed in a valley with shallow angles such that you could access the bolt with a wrench. It matters because you have to loosen that bolt in order to tension/release the serpentine belt. I can do it with the right wrench, but I don't have clearance for a socket, unless I do something like remove the fan shroud.
Old August 8th, 2017, 07:31
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
I've actually seen at least 2 different designs on idler pulley on xj's. The bearing is available but I don't know the number off the top of my head.
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old August 12th, 2017, 21:27
lawsoncl lawsoncl is offline
6203-2RS as I recall. I've fixed a number of idler pulleys that used the same bearing. Pretty common motor bearing size, just get a decent brand and be careful pressing it in/out.
Idler pulley RichP OEM Tech Discussion 2 August 17th, 2010 15:06
idler pulley went bad and... jeepnleo NorthWest Chapter 4 May 12th, 2009 21:58
Idler Pulley Keeps Going..... X9x A T I x7X OEM Tech Discussion 27 March 4th, 2009 19:01
Idler Pulley Mich88XJ Wanted: Private Party Only 3 April 8th, 2005 20:14
Idler Pulley nosajwp OEM Tech Discussion 2 October 31st, 2004 01:13
