Old June 3rd, 2017, 08:24
RCP Phx RCP Phx is offline
4.6 build starts today!!!
I finally get to p/u my block today so I can get started, I talked to Russ the other day about where my heads and intake are and they're about another week out!
Here's my parts list............
2000 XJ block - decked, bored .030" over, and align-bored w/ ARP Main Stud kit
Clearwater Cylinder Head improved 0331 head - Bishop-Buehl port/polish/62cc chambers/LS1 intake valves/port match w/ ARP head bolts
2000 XJ intake manifold - Bishop-Buehl port match/bore TB 62mm
BBK 62mm throttle body
Banks Revolver header
Hesco water pump
Comp Cams 68-232-4 camshaft - Lift(.460" Int/.476" Ex) Duration(250 Int/256 Ex)
Rollmaster billet steel(crankgear induction hardened) double roller timing set w/ nine position crank gear (+8 to -8 degrees)
Cam bolt with custom length thrust pin(no spring), shooting for .008" of end play
Sealer Power lifters
HarlandSharp 1.6 roller rockers w/ ARP rocker studs
Scat stroker crankshaft
Scat/Bishop-Buehl Chromoly 6.125" connecting rods bushed for free-floating Chevy wrist pins
Auto Tec 4032 Forged pistons/ -22cc D-dish w/ Chevy wrist pins and 1.385" wrist pin height
Sealed Power Moly piston rings
Clevite main/rod/cam bearings
FelPro gaskets/seals
ARP flex plate bolts
Brown Dog motor mounts
Crankshaft, connecting rods, pistons, wrist pins, flex plate, and harmonic balancer all balanced
Reciprocating parts - connecting rods, pistons, and wrist pins I weight matched to within .25grams across all 6 set combo's
Custom 2-1/2" header to downpipe adapter w/ O2 bung for my LM-2 A/F meter
Old June 3rd, 2017, 20:10
gradon's Avatar
gradon gradon is offline
Sounds like a yummy recipe!
Old June 4th, 2017, 12:48
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
Re: 4.6 build starts today!!!
That looks like the combo to build a Russ 4.7 stroker.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231 8.25/D30 ARB's 4.56's 33's deavers and a few other things.
Click here to join the red team
Old June 4th, 2017, 13:11
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
you'll like that setup. do you know what your CR will come in at?
with that setup and cam, you'll have awesome bottom end and pull hard through normal freeway rpm's. will be a lot of fun to drive around town.
tires will start to get expensive.
Old June 4th, 2017, 14:10
We'll yesterday I spent the afternoon checking/cleaning/ and painting. This morning I installed the cam and crank with the ARP studs.
Main bearing clearance - .002"
Rod bearing clearance - .002"
Crankshaft endplay - .002"
Cylinder/piston clearance - .003"
Next(tomorrow since it's getting hot and I am monoplegic) will be to drop a piston in to find TDC , check the deck height, and to dial in the cam.
I'm shooting for 9.25-9.4 CR! It is a Russ based build!
Old June 4th, 2017, 23:04
twinhauler's Avatar
twinhauler twinhauler is offline
Sounds like a great build. Pump gas 87?
Old June 9th, 2017, 16:46
We'll I finally got the bottom end together(it's not easy building a motor with one hand)! The rod clearance was great, next was TDC and degree the cam, had a little hic-cup but I figured that out, came out perfect! Piston ring gaps took a little while, but every things good to go there. Deck height was more than I expected but workable.
Edit : just realized there was originally no oil-slinger???
Old June 12th, 2017, 12:59
I wasn't able to accomplish a lot this weekend! I got the oil pump installed and fitted the cam bolt end play pin starting with a 1.5" x .250" +.002" hardened pin. It only took about five minutes and 2 pins(over-shot the 1st) to get the .008" of clearance I wanted. I discovered that my rocker arm studs and my oil slinger probably got tossed out with all the rest of my old parts(oh well) worse things could happen!Spent the rest of my time measuring the balance for ARP studs. Turns out the timing cover doesn't play well, but I've got a order in for the oil pan and valve cover.
Old June 12th, 2017, 18:06
Talyn Talyn is offline
That tapered piston installer really makes the install easy. Nice cam pin.
Old June 13th, 2017, 09:25
It's "Priceless" to me, I can't use any of my other types of compressors!
Old June 13th, 2017, 16:59
cal's Avatar
cal cal is offline
Looking good!
Old June 18th, 2017, 17:52
Well thanks to Russ I received my head and intake Saturday afternoon(love his work and the LS valvetrain with the Beehive springs)! Got the balance of my ARP hardware Friday. Been busy since, finished putting the long block put together and installed it in the Jeep!!!
With 62cc chambers I used a Fel-Pro 530HD head gasket so my QH should be about .040" and not knowing what the final "crushed" gasket height is, I'm thinking 9.3/1 max CR!
Old June 18th, 2017, 17:57
cal's Avatar
cal cal is offline
I want to say the gasket will be around .052. Not sure where that number came from but its stuck in my head.
the victor reinz gasket is 0.043 for sure though, and is what we use on all the race motors.
Old June 19th, 2017, 16:24
I measured the core/body of the gasket at .057". On Felpros sight they list it as .049-.059" which is kind of strange. That's why I just used .056" as a comfortable number.
I did have to massage the heat shield to clear the Banks header, but that wasn't to bad because I hadn't installed the motor yet!
Old June 20th, 2017, 10:43
yossarian19's Avatar
yossarian19 yossarian19 is offline
Looking at this, I kind of wish my SJ had an I6 so I could build one too. Cool stuff.
Winter on the Rocks starts today SandySteve InterMountain Staging Area 0 January 19th, 2017 10:56
Started my build today. Palmentech766 Midwest Chapter 5 January 20th, 2015 17:00
Jeepers Jamboree starts today..woo hoo rocknxj Sierra Chapter 22 August 2nd, 2008 19:53
No start yesterday, starts today Dirk Pitt OEM Tech Discussion 14 December 7th, 2007 08:03
No start yesterday, starts today Dirk Pitt OEM Tech Discussion 4 November 10th, 2007 09:00
