Vanimal
- escondido, ca
so i did an axle swap with one that was geared and locked, and now i have death wobble. i went through everything, and i cant find the issue. the last thing really left is the ball joints, which seemed good when i swapped it in.
the d30 i put in was an older one which had the 2 piece knuckles. my jeep is a 91, which had the newer one piece knuckles, so i swapped everything over to the new axle so i didnt have to mess with the different brakes and whatnot.
after doing some research, i noticed that the old knuckles had the threaded insert to adjust for the height of the ball joints, where the new knuckles dont have that. i seem to remember that the newer ball joints had vertical travel in them to make up for differences in dimensions instead.
so are the old ball joints incompatible with the new knuckles, potentially causing my DW?
