Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old September 16th, 2017, 03:18
Borgli Borgli is offline
Re: Help me understand shock valving?!
Originally Posted by Green XJ Jeep View Post
Your XJ will never ride like a Tahoe. Solid axle vs independent front axle
A set of long arms will help
I forgot about the solid v independent setup. The whole body feels a thousand times stiffer too. Talk about comparing apples and oranges.
Old September 18th, 2017, 13:03
kcox506's Avatar
kcox506 kcox506 is offline
Raced ECORS with 5100 Bilsteins and they never let us down. Tough shock, great for the price.
I now run valved 7/8 shaft Fox 2.5 Rem Res. with a flutter stack. Its super easy to tear down a shock if necessary. Rides like a dream over hole filled back roads. Obviously they're pricey, but getting Fox 2.0 that are valved to your weight and throw a flutter stack in there, I think you will be very happy. Comes down to your budget I guess. Can't go wrong with Bilsteins.
Ironman4x4fab Marketing Manager
2000 XJ ~4.5" '06 4.0
LP44 w/Rubi Air Locker & 8.8 ARB
231 w/ beefy stuff
Old September 18th, 2017, 16:23
Trouble Trouble is offline
I run 255/100 up front with a 7100 series 14" travel short body. been very happy with them. I have the same thing in the rear but some wierd valving thats not listed on their site.
foudn the rear was 246/94 with a 30% increase in high speed valving for use with air bumps.
Old September 19th, 2017, 21:56
TRCM's Avatar
TRCM TRCM is offline
The tahoe also has a separate frame...no unibody crap....which contributes to the stiffer feeling.
Shock valving JWARE26 JeepSpeed, Prerunner and Competition Tech Forum 4 March 31st, 2016 10:04
Shock valving and other shock questions. ocean_jet Modified Tech Discussion 20 August 20th, 2011 11:01
shock valving azxj95 Modified Tech Discussion 2 July 27th, 2009 18:02
Shock valving? Mike L Modified Tech Discussion 7 December 6th, 2004 01:09
Shock valving LT1XJ Modified Tech Discussion 2 September 2nd, 2003 11:32
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
