ScoobyDooJeep
- Sapulpa, OK
I've been reading for the past two days all the no start threads on this site and several others. I can't come up with what's going on with my issue. I bought a running '91 4.0 heard it run and actually started it myself many times before I pulled it out. I tore it down and had the head rebuilt. Put all new gaskets on it and put it back together. Put it in my '91 Cherokee. It cranks, has spark, has fuel to the rail. I've replaced the CPS, Coil, plugs, wires, cap and rotor. I get a good spark and I get fuel gushing at the bleed off valve(whatever it's called) and good stream from at the lines when cranking.
I'm at a loss. Someone please tell me it's something little I'm overlooking.
I also replaced the throttle body with the censors from another intake just to see. I've put a new interstate battery on it.
It will try to start when I hold the gas all the way to the floor. It's as if it's not timed right but I never moved or took the distributor out when doing the work to it.
Any help would be great.
