BenDiesel
- lynnwood washington
ok i have a 89 xj 4.0 aw4. i got it off a friend of a friend who was out todling around in a field when it went from running to not running(the guy is a idoit) so he took it to his mechanic brother who in the process thought the head was warped or the head gasket was bad. he took the head off and then let it sat for like 5 months. then i got it. i got a new renix head and had it cooked magnifluxed and gone though.
ok here comes the interesting part. i put the factory intake and exhaust manifolds to the new head and it started right off revved fine and every thing. the exhaust manifold was broken. so instead of driving it around i left it at my friends shop while i waited for my 92 ho apn header. and while i was at the whole modding thing i picked up a 99+intake. i mounted all of it to the new head along with some ho injectors from a 92, and this is what i got.
http://www.youtube.com/watch?v=TPjA1oLbGI8
so i figured the injectors were messed up and put the renix ones back in. and tried it again
http://www.youtube.com/watch?v=rtCSovA_z9w
there was a leak a fuel leak at one of the injectors. but it started, it would want to die every time i opened the throttle but it started. figured it was good so i finished the tps mod to the ho tb , fixed the leaky injector and tried it again. this time it was doing the same thing it was doing with the orange top injectors.
so i started probing around looking for a reason why this is doing what it doing. i replaced the cps and noticed its not getting any volts the sensor and same for the plug to the dizzy. no power not even while cranking.
so im :banghead: and have no idea what to do. going to the junk yard in a few days. was thinking of getting a coil and ignition control mod as well as a new main ecu. my only other option is to :explosion:flame:
