Nixt
- Plimmerton, New Zealand
OK, so I am evidently just a dumb-ass in love with a truck, and I want to re-animate the poor neglected thing...
My '96 4.0 2-door has been a paperweight for over a year, after a long series of errors trying to diagnose and fix a bad rough-run issue. (See here, and here)
I'm a mechanical novice, so I hadn't done what now seems obvious - pull off the valve cover. I found a loose pushrod (way loose). Had a mechanic neighbor look at it. He says collapsed/bad lifter and bent pushrod, and something about the part the pushrod slides in.
So its major engine work to fix it - and I want to get opinions on which way to go and what you know about costs (the labor mostly).
The options (?):
1. Have it rebuilt - new cam & lifters, and may as well do new valves while its out. May need bottom end work - new top makes too much compression??
2. Buy a remanufactured or rebuilt engine and have it put in.
3. Buy a junkyard engine and have that put in.
As I said - I'm seriously NOT an experienced mechanic - so I need input here...
TIA
The options (?):
TIA
