OldFarts4X4
- Florida
89 xj 4.0
I think I have some plug corrosion, and am wondering if anyone knows where any main harness plugs are located for the front turn signals / parking lights ?
What it's doing : When I turn on the parking lights or the headlights my Right dash turn signal indicator stays lit, the Right front parking light bulb is out completely at that point (not lit), and if I then turn on the right turn signal the dash indicator works, but the parking light side of the circuit blinks at the bulb (dim) not the turn signal side of the bulb. This problem is in the front only, the rear lights work perfectly.
The right side does this 100% of the time, and once in a great while the left side joins in just for fun , and then both sides do it exactly as described above . When it's just the right side doing it, the left side functions perfectly inside and out.
Flasher and all vehicle bulbs have been changed, sockets are corrosion free and wiring looks factory new (nothing has ever been cut or spliced or repaired)
That is why I am guessing a plug somewhere ............
Any thoughts ?
Thank You :cheers:
Any thoughts ?
Thank You :cheers:
