Old January 10th, 2018, 22:02
trippled trippled is offline
Re: Rear inner stiffeners
Originally Posted by Hypoid View Post
It sets up a condition called "stress concentration," but, do as you please.
This. Sharp corners=stress risers. It's why you should round corners off of things like mounting plate.
Old January 11th, 2018, 07:28
burntkat burntkat is offline
NAXJA Member #1145
I seriously doubt that's a concern after you've melted the corners into puddles mingled with the base metal, and the welds are surrounded by large amounts of undisturbed steel
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old January 11th, 2018, 15:18
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Your probably right. However, square holes in a rosette weld application is about as dumb as it gets. There's a reason why you don't see square windows on an airplane. Unfortunately it took many of them to fall to the ground for engineers to see the problem.
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old January 11th, 2018, 17:24
TRCM's Avatar
TRCM TRCM is offline
or square doors/hatches on a ship (not talking about non-structural doors).........it's a lot easier for a crack to propagate from a corner than from a side....which is what a rounded off corner is
Old January 11th, 2018, 18:21
Hypoid's Avatar
Hypoid Hypoid is offline
And I'll never see the cracks in the base metal, from my house.
Like I said, do as you please.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old January 12th, 2018, 06:52
NAXJA Member #1145
Definitely agree on those points! Although internal pressure isn't really the issue here.
Old January 12th, 2018, 08:39
XJensen's Avatar
XJensen XJensen is online now
Haha. Interesting points. I was going with round holes because I figured it would be easier while making my little circle motions. Lol
M
-------- www.4x4TrailMaps.com --------
Old January 12th, 2018, 10:24
Internal pressure wasn't the problem. An airplane (or any well engineered structure) is designed to twist and deform without concentrating stress into any one point. This is exactly how cracks form.
http://en.wikipedia.org/wiki/De_Havilland_Comet
Old Yesterday, 00:18
Hypoid's Avatar
M
Hmm, we have ships and airplanes, why not trains??? I might have seen some cracks in some steel, a time or two...
I used to work in the rail industry, so, I tend to copy approved practice for railcar repair. Notice the call-outs for a radius on the transitions.
Old Yesterday, 14:26
XJEEPER's Avatar
XJEEPER XJEEPER is online now
NAXJA Member # 13
Options
https://www.jcroffroad.com/product/XJUNS-R.html
Speak the Truth-Question with Boldness-Speak without fear.
Old Yesterday, 15:33
XJensen's Avatar
Originally Posted by XJEEPER View Post
I would have grabbed a set if these for the outer side but already have some installed. They just don't wrap under.
I see people make them for the front now that wrap under. I need to do the front soon and have plates. Wonder if it's worth selling and getting some that wrap under in the first place.
I plan to and if it's a good fit and saves me time I would be all for it
Old Yesterday, 15:35
NAXJA Member #1145
The bottom looks pretty straightforward, IIRC (I am not in the XJ today). I would think it would be easy to template it with cardboard, a hammer, and some snips. Trace it onto plate and weld it in.
Old Yesterday, 19:58
Heavyopp Heavyopp is offline
$54 shipping for the stiffeners in the second post to NJ
That's having them made in 3/16 plate
I don't know about the rest of you but adding 30% to the cost for shipping makes me want to fab them myself
Old Yesterday, 20:34
I built my mid and rears out of 3x3x3/16 angle iron. It's a time consuming job but it works well. They're a little short (don't go as close to the floor as I'd like) in rear section but oh well.
Old Yesterday, 21:29
I just had to drop my fuel tank today -- Fuel pump went ---- Saw that previous owner cut a 4" rectangular hole in the frame rail above the nutsert -- guess they had problems securing the trailer hitch
Anyway -- I will weld in a plate while the tank is out -- These inner stiffeners would be perfect but shipping costs are ridiculous -- I'd rather spend the money on a full sheet of 3/16 steel and make my own
Rear stiffeners section XJwonders NAC Classifieds 0 June 26th, 2017 12:50
rear stiffeners Oil Town XJ Modified Tech Discussion 37 March 27th, 2010 21:22
Rear frame stiffeners XJtattoo Modified Tech Discussion 4 November 25th, 2009 10:11
rear uni-body stiffeners? POLAR_JEEP_04 Modified Tech Discussion 1 August 1st, 2009 21:08
