ebrake cable clamp question?
villestrip
Roseville CA
did a lot of searching and haven't found the answer. Where can i buy the cable clamps that are use when doing the zj brake conversion on the rear? Sorry if this is a dumb question.
Got a link to the conversion you're doing? I'm drawing a blank about what you're asking for.
villestrip said:
i have a 98 xj with an 8.25 rear end. I'm using rear disc off a 98zj. to make the ebrake cables work i need to do the whole loop the cable around the ebrake lever. I need to know where to buy the clamps i've seen people use.
like fatwreck has here
http://www.naxja.org/forum/showthread.php?t=14229&highlight=dxj
Like this?
That looks like something I've seen down the hardware aisle at ACE.
