drbobxj said:Hey..
just thinkin.. has anyone made there own SYE?? could you just get a york bolt it to the shaft, with the end hoseing still on..??
5-90 said:OK - here's a hint...
Search "Poor Man's SYE", and see what you get. Look for the post started by old_man - all his idea.
5-90
Zuki-Ron said:Did exactly what you said. No dice.
John90XJ said:I did it with a 27 spline Spicer CV style slip yoke that was cut down to work with the seal housing from an RE hack & tap. I'm now able to run a front shaft in the rear. Total investment is about $140. So far, so good.
Zuki-Ron said:Do you have a PN for that yoke?
Zuki-Ron said:A real low budget SYE was descibed to me by a friend who ran this exact setup for years.
Press off your stock Yoke. Slide it on and drill/tap a hole up the middle for a fine thread bolt. Bolt it on and take your stock shaft down and have them install a slip joint.
Here's the hard part> Press your U-Joint back on your yoke, on the truck and install the rear joint. He had a 96' with the external slip, and I think he had to shorten the Yoke before he could bolt it on.
