Sarge
- St Louis, MO
After almost two years, one hernia, and some late night back pain my wife bought me a winch to help load my sewer machine into the van. I've got some questions on mounting it tho. BTW, Superwinch T1500 with 75 foot of cable.
The winch will be used to pull a main line sewer machine up a ramp and into the van. The machine weighs in at 275lbs so I figure the initial pull to get it rolling should be close to 500lbs or so. The winch has power in and out.
It will be in the back (cargo area) of the van. Two possible spots, both well inside, both requiring me to run cable from the battery back. It does have a remote control unit so in both cases I can run the winch from outside the van. Vans battery is on the passenger side.
Spot one...preferred.
The winch would be installed on the drivers side, under a shelf unit. It would most likely have to be turned approximately 45 degrees or would pull off to one side constantly. I planned to mount an eye bolt to redirect the cable to allow for a straight pull into the van. Total length of pull is only about 6 foot. There is a protective wall there to mount the control unit to. This is my preferred spot as it gives me more room in the van, the winch is protected under the shelving unit, and it centers the weight load.
Spot two
Winch would be mounted approximately passenger side of the cargo area in about the center. The pull would be a straight pull, no need to change cable direction. No protection for the winch so I would probably build a small wooden cover. The control unit would most likely end up mounted to the interior roof. Total length of pull again 6 foot.
Any input? Considering the length of battery cable needed, any special type needed? Any special concerns?
Considering the weights concerned; machine runs 275, to get it rolling probably close to 500; can the winch be mounted straight to the van floor or should I use a plate? I have enough 1/4" to add a plate both top and bottom or as needed. Definitely needs to be removable so I can use it when I finally upgrade to my next van.
Sarge
Spot two
Sarge
