Where are these suppose to go?
What difference does that make though? Like between if it was a 90 and since it's a 94
Early XJ with 242 as with later 91-up XJ have non-disco D30 with 1-piece shaft. This would effectively make the vac setup not function so no 4wd light would turn on. I believe that the plug exists and need to be connected for the light to function.
Do you happen to know where it plugs in to function the light?
