P0432 -- and stuck exhaust valve
Heavyopp
Middlesex, NJ
Ok got a problem -- 2000 cherokee -- 4.0 with cali emissions has the 2 pre cats
Replacement motor -- 27000 miles on motor -- New walker pre cats -- new NTK o2sensors -- 600 miles on both pre cats and o2 sensors
I keep getting code p0432 -- Clear it and it comes back
Now I had a problem with the previous motor -- didn't know the #2 cylinder exhaust valve was stuck open -- Had installed the new pre cat manifold and the O2 sensors on the bad head -- Had what I imagine was raw fuel dumping into the exhaust due to the stuck valve -- caused exhaust pipe after cat to glow orange at night
In searching for a replacement head I stumbled upon an entire engine with 27000 miles for $350 -- swapped that in using the newly replaced pre cat,O2 sensor combination
My question is -- If I had raw fuel dumping into exhaust - What did it damage?
I never drove the XJ but I did run it above idle while trying to diagnose the stuck valve -- Finally a compression check found it
That pre cat pipe is expensive, I hope I didn't cook one of the cats -- chances I cooked an O2 sensor? Is there any way to test each O2 sensor for damage?
Hope this make sense -- thanks for any help
Jer
More than likely it nuked the cat. I've also seen a lot of aftermarket cats still cause efficiency codes.best way to check would be monitor rear o2s when driving and see if one is toggling like a front one would, which would indicate a bad cat.
You could check for exhaust back pressure which would further point to a bad catalytic converter.
^what he said.
As an addition. The sensors can also melt down as well. Rule of thumb: If the cat is hot enough to glow, the sensors are too.
so I had a friend put the good snap on scanner on the jeep -- we get a lost/ intermittent signal with the downstream bank 2 oxygen sensor -- it was too cold to crawl under there to check the wiring but at least I have a place to start
When I dumped raw fuel into the exhaust it was from cylinder 2 which would be bank 1 so hopefully the cat survived and didn't melt down
I'm leaning towards an 80% chance of survival. It really depends on how long the cat was run like that.
It was never driven with stuck valve -- maybe total idle time of 2 hours while playing around before I compression tested it
This 2 hours run time was spread out over a few weeks
I'm thinking the precats are fine and I have a bad sensor, bad wiring, loose connection
It's too stinking cold to mess with it now -- runs and drives fine -- code hasn't returned yet
