Dingo509
- Yakima, WA
Which one?
Griffin, Be Cool, or alumrad.com
Dingo
Dingo
themud said:I run alumrad it does work just look where I live, it replaced a two row modine for me...
themud
and when I pop the tanks I have a friend fire up the tig and weld me some new tanks
Snarky said:I hope this is not too far off your post, but I was just wondering if an aluminum radiator will crack if it is at running temperature and cool water hits it? I thought I heard somewhere that aluminum will crack if it cools down too fast. Just thought I would ask, and maybe this will save you from cracking it if you didn’t already know about it. (That is if it’s true) :wave:
Planetcat said:I have an alumrad too. Replaced the 3-row modine after lengthy overheating drama. Price on alumrad is right too. It's one core with nice big tubes going through it. Keeps the jeep at t-stat temp, even when towing my 3800 lb. boat in 96* weather. Installed it in 45 minutes.
Snarky said:Forgot to mention this on my earlier post, what are the advantages with an aluminum radiator anyways? Other than looking cool under the hood :laugh3:
Dingo509 said:What are you running for fans? Do you have the a/c condenser?
I have been fighting a overheating problem and an aluminum rad is my next route. Dingo
Storydude said:NOTHING cools as good, or is as durable as a Copper/Brass Rad. Al. rads are mostly for weight reduction, and the Bling factor.
GroversXJ said:I'd like to know why rather than someone stateing what could be just an opinion. I also have cooling problems and will be looking for another rad but I want to get something that fixes the problem the first time as money is tight.
I'll agree that rad design is more important than material but part of rad design is choosing the material that will conduct heat best for the specific application.Storydude said:Rad design is more important than material. I could make you a 4 core rad that would not cool off crap, and I could make you a 2 core that would cool a locomotive...Out of the same materials.
The overheating of my engine during the 110-120 days here in the desert while I'm wheeling slow says yes I have cooling problems. I am fine driveing down the road when I maintain some speed but I don't know when the rad was replaced last as I've only have the rig for 2 years. So a new rad may solve any cooling problems I have as it may be clogged somewhat.Storydude said:If you have cooling problems(are you sure you REALLY are?) a new Rad is a stop-gap. Clogged rads, usually mean clogged passages, and bad waterpumps.
First the article is written by the copper industry so of course they will be boasting the benefits of copper, but what it all really comes down to is their NEW DESIGN of a copper rad that is brazed and has thinner tubes. An aluminum rad with thinner tubes using the same new design may be even better than their new copper design. They base their comparison on the energy used to make the new copper rad's and the energy recovered by recycling them, and compare those energies to aluminum radiator energy costs to determine part of their benifits. I don't want to destroy the planet or anything but to me in my jeep, if I want something that will cool it down, then I'd be willing to pay the extra costs during the purchase to use the material that takes more energy to produce if it will work better for its purpose (cooling down the rig).Storydude said:http://www.copper.org/applications/automotive/design-innovations.html
Copper Vs Aluminum. Some good reading.
Planetcat said:You should call the guy (Bob McCulloch?, I think) who owns alumrad. He's a really nice guy and will spend time on the phone with you explaining radiators and cooling.QUOTE]
I got off the phone a few hours ago with Brian there. He talked about 2 mins and said Said ive got to grab the other line" and click. So i am now looking into either Griffin, or BeCool. I will not deal with someone hanging up on me. The Product may be great but there customer service Sucks.
So any body have experience with either BeCool or Griffin?
Dingo
That would be copper/brass. [/W m-1 K-1]: 400 http://www.webelements.com/webelements/elements/text/Cu/heat.htmlGroversXJ said:I'll agree that rad design is more important than material but part of rad design is choosing the material that will conduct heat best for the specific application.
If you are cooling while moving, and overheating while going slow, it's an AIRFLOW problem...not a rad problem. check your clutch fan, or wire up the AC fan as an Aux.The overheating of my engine during the 110-120 days here in the desert while I'm wheeling slow says yes I have cooling problems. I am fine driveing down the road when I maintain some speed but I don't know when the rad was replaced last as I've only have the rig for 2 years. So a new rad may solve any cooling problems I have as it may be clogged somewhat.
I don't mean to go off on anyone I just like to understand the reason behind the design or claim, thats why I, like many others here like these forums.
The same can be said for Aluminum. Aluminum rads NEED to be an alloy of Al. Pure Al is almost worthless as a construction material. Too soft, and unstable as an element. Make it an alloy, and it's stronger, and more workable.nosajwp said:How many of you think your radiator is all copper? I'd be extremely surprised if it were, considering the high costs of pure copper. More than likely is a bronze or brass alloy, which would have a lower coefficient of heat transfer than pure copper.
