dan1977p
- Virginia Beach, VA
As I said above, I'll be the outlier here. Being in your 70's, are you going to be willing to not only do a lot of the manual work required or will you need to pay for the labor in addition to the parts. Labor costs will kill your budget in a heartbeat. There is also the factor of having to climb in and out of a lifted rig. It really sounds like you won't be beating this thing up and just want to get off the beaten path and just need to freshen up the suspension and maybe the steering if your tie rod ends are loose. Someone said it earlier, once you start the 'upgrade' process, it sets you down a path where you need to suddenly change a bunch of things that were just fine before. Be careful of that. I'd love to spend your money but based on what you're saying, you don't really need more than just the periodic maintenance items to be freshened up and you're good.
Edit: The one thing I think I missed is recovery points. Trailer hitch in the back and tow hooks up front just in case you do get into a pickle.
