broken rear upper shock bolts
A603XJ
New Hampshire
so i started to remove the rear suspension getting ready for the 4.5 Rubicon express lift. just like every other xj my upper shock bolts snapped off in the body even after letting some PB blaster sit on them over night. just wondering what is the best way to go about fixing them. if i should drill out and go for a bigger size bolt or drill them out and use a bolt with a nut and washers right though the mount?
